From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Re: Throttle Performance Switch (sobrino)
Check the archives and do a search. Seems like there was a recent post on this topic. I have never used one and may be mistaken, but I thought the consensus was these weren't worth the money. Admittedly, I may be wrong. Others will hopefully add their experience.
I've been using one for the last year......works good.....don't care what everyone says.....it "WORKS"....for me......Cheap, buy any means...so the debate goes on...and on....and on......to each his own!!!!!!!!!!!!!!!!
:seeya :seeya :hurray: :hurray: :cool:
I bought one and it set a code 21. Sent it back for another and it too set a code 21. I even tried setting the TPS lower since mine is adjustable and I still got the high code. I ran across a 90 last year that was getting the same code with his Performance switch unit. His TPS is non-adjustable so either way it sucks!! After unhooking it and re-setting the compter the high codes were gone. I would NEVER recommend this junk to anyone!
