Alternator question
Old May 5, 2003 | 11:00 AM
Toe's Avatar
Toe
Default Alternator question
When replacing the alternator on my 1990 I ran into a problem with the lower mounting bolt. How do you remove it? It seems too long and it hits the fluid resevoir. Is there a trick to removing it?
Old May 5, 2003 | 11:16 AM
90EXPVette's Avatar
90EXPVette
Default Re: Alternator question (Toe)
I remember the same thing happening and ultimately I think I moved the resevoir (by pushing it with my finger) just enough for the bolt to clear. Wait for others to chime in though since it's been a couple of years and I don't have my Manual here at work. I'll look it up when I get home and post if you haven't gotten an answer by then.
Joe
Old May 5, 2003 | 11:23 AM
Toe's Avatar
Toe
Default Re: Alternator question (90EXPVette)
Thanks! I just know it can't be a GM design fault!
Old May 5, 2003 | 01:31 PM
TA's Avatar
TA
I remember the same thing happening and ultimately I think I moved the resevoir (by pushing it with my finger) just enough for the bolt to clear. Joe
Thats exactly what I did and I'm starting to get pretty proficient at it since I've done it twice in the last three weeks :crazy:
I did remove one of the bolts for the resevoir to make it a little easier to move out of the way
Old May 7, 2003 | 09:25 AM
Toe's Avatar
Toe
Default Re: Alternator question (TA)
Thanks for the advice folks! Alternator is in and she purrs like a kitten! :cheers:
Old May 9, 2003 | 02:51 AM
90EXPVette's Avatar
90EXPVette
Glad that I could help! :cheers:
To Alternator question
