How do you clean a LT1 Engine!
Old May 20, 2003 | 07:56 AM
Joeyvette's Avatar
Joeyvette
Default How do you clean a LT1 Engine!
I was wondering how you guys clean your engine without ruining the Opti. My engine has the usual sand and crap on it and I would like to spray it down. How do you cover the Opti? And what do you clean the engine with? Thanks.
Old May 20, 2003 | 08:03 AM
JB666's Avatar
JB666
Default Re: How do you clean a LT1 Engine! (Joeyvette)
Good question, I'll be watching this one :)
Old May 20, 2003 | 09:22 AM
turbota's Avatar
turbota
Here is what I do: I use a shop vac to blow or suck sand and leaves and other stuff out. I use simple green or greases lighting to clean spots of grime and grease. Then when I have the engine clean I spray that no touch tire foam all over the the engine hoses and fender well for that just detailed shiny look. Works well for me. It takes a little time and effort, but it looks good after.
Old May 20, 2003 | 12:31 PM
ScottsLS3's Avatar
ScottsLS3
Default Re: How do you clean a LT1 Engine! (turbota)
Well i spent hours upon hours last week doing this, I started by spraying simple green everywhere but the front of the motor ,then witha hose I very lightly sprayed the underside of the hood and the top and sides of the motor but not the front , being careful not to wet the opti. Both front wheels were off also so I can the suspension really good. Then I dried every thing off by hand with a towel. After that I went over every thing in the engine with a rag and 303. The whole engine looks better than new now. But it was very time consuming. :yawn: good luck!
Old May 20, 2003 | 02:29 PM
Eric 96's Avatar
Eric 96
I spray down everything with Simple Green, let it sit, then rinse off with low pressure water, start the engine, and let it heat up and evaporate the water.
Old May 20, 2003 | 02:49 PM
GlockLT4's Avatar
GlockLT4
Default Re: How do you clean a LT1 Engine! (Eric 96)
First i turn on the air compressor .. then i blow everything down reallly really well with 140psi :D . If used properly, you can blow out greasy dirt that sticks to your block this way too!
After that i go to town by hand with paper towels and simple green. :yesnod: For shineyness .. i use Meguairs tire shiner on all the plastic and rubber parts :cheers: . I use Mother's alumnium polish on the unpainted (ie not the red intake) metal under the hood. That stuff works really well! :yesnod:
[Modified by GlockLT4, 1:53 PM 5/20/2003]
Old May 20, 2003 | 04:25 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
:withstupid:
Old May 21, 2003 | 01:23 AM
R23HTC's Avatar
R23HTC
Default Re: How do you clean a LT1 Engine! (_freakmonkeydogboy_)
One extra large bottle of Simple Green, two rolls of shop towels, and a lot of elbow grease! :D Took me two days. I never realized the frame was black! :eek: :D :thumbs:
Old May 21, 2003 | 02:23 PM
MTVette's Avatar
MTVette
Default Re: How do you clean a LT1 Engine! (R94 LT 1)
A bottle of Simple Green, an old toothbrush, lots of rags, and extra elbow grease!
Old May 22, 2003 | 07:24 AM
Joeyvette's Avatar
Joeyvette
Thanks for the replys. I'll try the simple green out. :cheers:
Old May 22, 2003 | 01:23 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Joey,
Here's the scoop..... The problem with cleaning your engine with water is due to the sensitive nature of the OptiSpark, MAF, IAC, and TPS. The OptiSpark is prone to allow water from the outside migrate to the inside due to a bad seal design. I wash my engine at least once per month (with high pressure water) but not without precaution.
1st ~ the OptiSpark is located directly behind and below the water pump. I take old cotton rags and stuff them in and around all areas of the water pump. Next, I take a rag and wrap it around the throttle body to protect the IAC (Idle Air Control) and the TPS (Throttle Position Sensor). If your Vette is 94 or later, it has a MAF on the inlet air duct. Wrap a towel around this unit. The reson you should use cotton absorbent rags vs. plastic is that the rags absorb and don't deflect water like plastic does.
Now, spray away ~~~ but use common sense. The rags are there to protect the components from indirect spray. If you point the wand directly at any of these components ~ you are asking for trouble.
This allows you to wash away the everyday dust and dirt that accumulates under the hood. When done, remove the rags and Simple Green that small area you avoided with the spray.
~ Purp
Old May 23, 2003 | 07:11 AM
Joeyvette's Avatar
Joeyvette
Default Re: How do you clean a LT1 Engine! (PurpleC4)
Thanks Purple. I will do it the way you reccomended. :cheers:
Old May 23, 2003 | 03:19 PM
Rubyred's Avatar
Rubyred
Clean it :confused:
Old May 23, 2003 | 03:47 PM
vette_dreamer's Avatar
vette_dreamer
Here is my method-pay some one $20 to do it for ya :D
Old May 24, 2003 | 06:59 AM
Joeyvette's Avatar
Joeyvette
Default Re: How do you clean a LT1 Engine! (vette_dreamer)
How do you know the guy you are paying 20 bucks to is not spraying the engine down and possibly endangering your opti :confused:
To How do you clean a LT1 Engine!
