Dyeing Carpet?
Old May 23, 2003 | 10:17 AM
GRAYT VERT's Avatar
GRAYT VERT
From: Not QUITE the armpit of Southern Maryland, but scary close...
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'06
Default Dyeing Carpet?
Has anyone out there ever dyed their carpet? Mine is gray, but is faded and has some minor spots. A friend told me that it is easy to dye carpet back to the original color. Is this a good alternative to new carpet? Or too much hassle?
Thanks,
Dave
Old May 23, 2003 | 10:22 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Dyeing Carpet? (68someday94now)
I did mine. Used RIT dye, rubber gloves and a sponge. Just don't get the carpet overly wet. It'll work...
And welcome to the :party:
[Modified by edsalinas, 8:23 AM 5/23/2003]
Old May 23, 2003 | 10:53 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: Dyeing Carpet? (edsalinas)
I changed out all my carpeting this spring. I think I counted 15 separate pieces. It was one of the best projects I have done so far and a beginner with patience can do this
The new carpet is very :cool:
[Modified by brdd, 9:54 AM 5/23/2003]
Old May 23, 2003 | 11:21 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Welcome 68someday94now!! :cheers:
I'm also thinking of dyeing the carpet in my 87 so I'll give this a TTT. :thumbs:
Old May 23, 2003 | 11:41 AM
GRAYT VERT's Avatar
GRAYT VERT
New to this forum, will take a while to get the jargon down. What does TTT mean? :confused:
Old May 23, 2003 | 11:44 AM
War Machine
to the top :thumbs:
Old May 23, 2003 | 11:47 AM
War Machine
Default Re: Dyeing Carpet? (War Machine)
I think I heard somewhere before that the dye will come off onto your clothes. Anyone know if this is truth or myth?
Old May 23, 2003 | 11:50 AM
Eric 96's Avatar
Eric 96
I dyed the carpet in my '70....I used an aerosole spray dye that I bought at Pep Boy's.
Old May 24, 2003 | 12:55 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Dyeing Carpet? (Eric 96)
How did it turn out???? :cheers:
Old May 24, 2003 | 07:29 AM
edsalinas's Avatar
edsalinas
It might come of if a cheap product is used, but not with "RIT" dye, it's been around for ever. Mine hasn't & it's a year old now ? ?
Old May 25, 2003 | 08:59 AM
dmorris's Avatar
dmorris
I used the RIT dye method on mine and it is a big improvement. Mix the dye, get your color match just right, and you will be satisfied. Put the dye mix in a spray bottle, spray the carpet, and work the dye in with a brush. Wipe any overspray off with a wet towel. After it dries, rub over the carpet with a wet towel to remove extra dye.
I did mine about 4 months ago. I haven't noticed the dye rubbing off. It was a big improvement. I will eventually replace the carpet, but it did buy me some time before I have to drop the bucks for carpet. It doesn't look new, but I looks much better.
Old May 25, 2003 | 10:36 AM
War Machine
Thanks for the tip on RIT!! :cheers:
Old May 25, 2003 | 04:24 PM
GRAYT VERT's Avatar
GRAYT VERT
Just wanted to say Thanks, Everyone, for your advice!
Looks like the RIT is the way to go!
Dave
:seeya :flag
Old May 25, 2003 | 10:38 PM
edsalinas's Avatar
edsalinas
ur welcome.
Rit will take care of it, just be careful & you'll be fine......
:steering:
Old May 26, 2003 | 12:16 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Default Re: (War Machine)
[QUOTE]Thanks for the tip on RIT!! :cheers:
Did my carpet in my '85 today with the RIT dye. Carpet looks like new! Thanks for the tip, Ed. You saved me a bunch of cash! :D
[Modified by H P Bushrod, 5:17 AM 5/26/2003]
To Dyeing Carpet?
