Antenna question....
Old May 30, 2003 | 10:14 AM
CMYC4GO's Avatar
CMYC4GO
Default Antenna question....
Has anybody here ever installed or know about those antenna switches that Corvette Central advertises? I don't listen to the radio much, but I do use the hell out of the CD/Tape player, and there is no sense in the antenna going up to listen to a CD or a tape. I'm wondering how hard are those switches to install, and where do you put them?
Old May 30, 2003 | 10:23 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Antenna question.... (Klimper)
I just used a toggle switch and mounted it in the panel behind the ALDL connector. Wired it in to the pink antenna wire behind radio. I have only used that switch twice !! :D :cheers:
Old May 30, 2003 | 03:07 PM
C4Crazy787's Avatar
C4Crazy787
Check out my Tech Tip "1984-96 Antenna Bypass Switch" in the C4 section, got everything for about 10$.
:seeya ... Denver... :flag
[Modified by C4Crazy787, 3:24 PM 5/30/2003]
Old May 30, 2003 | 03:15 PM
PsychoVetteOwner's Avatar
PsychoVetteOwner
on most aftermarket stereos, there is a power antenna lead, just be sure to hook that up, and as long as you dont turn the radio itself on, you should be ok
i know the alpine i have in mine never raises the antenna until i set it to radio, and thats how i have it wired
Old May 30, 2003 | 05:04 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Antenna question.... (PsychoVetteOwner)
:iagree: :yesnod:
Old May 31, 2003 | 01:01 AM
LaVidaLoca's Avatar
LaVidaLoca
Larry, we can get a switch locally and I'll put it in for you. It's an easy job.
To Antenna question....
