Front Speaker Problem
Old Jun 6, 2003 | 10:15 AM
MrBigButt98Conv's Avatar
MrBigButt98Conv
Default Front Speaker Problem
Hello All.
I am hopeful someone can help me out. My 91's right front speaker has a swirling, cracking sound to it. Even when the volume is turned down it can still be heard. Is it the speaker or the relay? Or something else. Thanks so much..
Old Jun 6, 2003 | 10:20 AM
PsychoVetteOwner's Avatar
PsychoVetteOwner
Default Re: Front Speaker Problem (MrBigButt98Conv)
there's a few things you can check
the wiring off the back off the speaker
and that speaker's wiring to the head unit
odds are one of the ends isn't 100% connected
since it's only that one speaker, odds are thats what it is
also, while you have the speaker out, check the overall condition of the cones, but if it's just a whiring sound, they should be ok
[Modified by PsychoVetteOwner, 10:20 AM 6/6/2003]
Old Jun 6, 2003 | 11:07 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Each speaker has its own amp, located at that speaker. What you are describing sounds like an amp gone bad. They are rebuildable or you can replace them with new ones. Not cheap either way, but it will fix your problem.
Let me know if you need more assistance. :yesnod:
Old Jun 6, 2003 | 12:34 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Front Speaker Problem (brdd)
:iagree: Sounds like a shot amp. There is a tech tip on how to replace the capacitors and rebuild it. Cheaper than sending it out or buying another.
To Front Speaker Problem
