C4 PKE programming
Old Jun 18, 2003 | 03:38 PM
sp802's Avatar
sp802
Default C4 PKE programming
I have a used PKE coming from ebay and I don't have the owners manual.
I DONT want it to open when I get close, I want to program it to only open and lock when I push the button. How do I do this?
:cool:
Old Jun 18, 2003 | 04:12 PM
n1kki6's Avatar
n1kki6
Default Re: C4 PKE programming (sp802)
actually the pke only has the option to unlock when close, or not on at all, their is no way to make it function as a normal keyless.
Old Jun 18, 2003 | 04:21 PM
sp802's Avatar
sp802
Default Re: C4 PKE programming (n1kki6)
the PKE sets and resets every 5 seconds when I am installing or removing the car cover, honking the horn each time. It is driving me crazy. Can this be adjusted to only set when I am 20 feet from the car?
:banghead:
Old Jun 18, 2003 | 04:25 PM
TimC's Avatar
TimC
CI 3-4-6-8-9 Veteran
Press and hold the door button when in range. It'll cycle through the and keep them from locking and unlocking. :cheers:
Old Jun 18, 2003 | 04:38 PM
sp802's Avatar
sp802
Default Re: C4 PKE programming (TimC)
I thank you, and my neighbors at 6am thank you! :party:
Old Jun 18, 2003 | 04:42 PM
vette_dreamer's Avatar
vette_dreamer
:banghead:
nope, you can't reset the distance. the sensor on the car are located near the 2 doors and at the rear of the car. the effective radius is about 3 feet from those 3 locations. hence when you remove the car cover, you are going in and out of the effective radius, thus turning on and off the alarm. either leave the key away from the car or turn the alarm off by holding the door lock button on the PKE fob for about 2 seconds and you will hear the door locks click, you have disarmed your PKE. To arm it again, hold the door lock on your PKE fob for 2 seconds till door lock cycles.
Old Jun 18, 2003 | 07:09 PM
GoodbyeGirl's Avatar
GoodbyeGirl
Cruise-In III Veteran
The fact that you can't use it as a "normal" key fob (meaning, the lock/unlock button on the FOB doesn't do anything) when the PKE is off is the one thing I don't like about it.
Overall, I think I'm finally getting used to it!
Old Jun 18, 2003 | 10:58 PM
JB666's Avatar
JB666
Default Re: C4 PKE programming (GoodbyeGirl)
Oh my God, my PKE annoys me to no end. Beep/lock/Beep/lock/Beep/Lock. I'm only getting the damn LAWN MOWER OUT, shut up already!!!
My neighbor's dont hate my alarm, they just think I'm fried for yelling at a horn!!
Old Jun 19, 2003 | 01:07 AM
VetBoyZR1's Avatar
VetBoyZR1
Default Re: C4 PKE programming (Jbaker)
The C5 has a switch right on the key fob to turn it off and on. That was a good idea :cheers:
To C4 PKE programming
