Where is my O2 sensor ?
Old Jun 18, 2003 | 09:02 PM
Stingraynut's Avatar
Stingraynut
Default Where is my O2 sensor ?
I’ve searched through the manual – plenty of info on the O2 sensor but can’t find where it is.
There is a sensor on the bend in the LH exhaust, is that the O2 sensosr or an exhaust gas sensor ? Should there be one on the RH side ?
TIA
S’nut
Old Jun 18, 2003 | 09:22 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Where is my O2 sensor ? (Stingraynut)
:cheers: Depending on the year of your vehicle, you have either one or two
They are(it is) located just below the connection with the exhaust manifold in the Y Pipe.
It will be the only device with a wire coming out of it that you will see in your exhaust pipe :D
Old Jun 18, 2003 | 11:34 PM
Stingraynut
Default Re: Where is my O2 sensor ? (jackdaroofer)
Oops, sorry, I forgot to put my year, jackdaroofer, I read your post a while back about that – good idea (mine’s an 88)
Thanks for the info, the local exhaust shop are making up a new pipe for me tomorrow as the LH one has blown through. They are planning to weld a nut onto the pipe for the sensor . ( I’m a long way from any Corvette parts stockist.)
They mentioned that the sensor has to be the correct distance inside the pipe so it sounds as if they know what they’re doing…………..!
BTW - My engine bay is still looking good from the one spray of Armorall Tyre spray, I’ve told lots of people about it, thanks again.
S’nut
Old Jun 18, 2003 | 11:40 PM
vizkiz's Avatar
vizkiz
Threadkiller
Cruise-In 9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09
Mine is an 84, do I have 1 or 2 O2 sensors?
Old Jun 19, 2003 | 07:48 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
S’nut
:cheers:
Vizkiz first, you should have only one and it should be about 6" or less below the junction of the manifold and the engine pipe
S'nut, same thing
I appreciate your giving me credit for the armor all thing...but I don't think it was me :blueangel:
I use Pledge under the hood...actually I am not a big armorall fan...but hey, if it works, I am glad I recommended it :D :D :D
:seeya
:steering:
Old Jun 19, 2003 | 07:51 PM
vizkiz's Avatar
vizkiz
Threadkiller
I'm not too sure about that. My O2 sensor is on the driver's side, and one of my father's friends has an 84 with the O2 sensor on the passenger side.
Old Jun 19, 2003 | 11:14 PM
flannel_man's Avatar
flannel_man
Default Re: Where is my O2 sensor ? (vizkiz)
:withstupid: :confused:
To Where is my O2 sensor ?
