Option codes
Old Jun 19, 2003 | 09:18 AM
86shark's Avatar
86shark
Default Option codes
Is there a listing of all the option codes for the C4 somewhere?
Tia
Old Jun 19, 2003 | 09:26 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Default Re: Option codes (86shark)
Try here http://www.idavette.net/facts.htm just click on the year.
Old Jun 19, 2003 | 10:30 AM
86shark's Avatar
86shark
Default Re: Option codes (joecaver)
Thank you, I seem to have a lot more numbers or codes inside my armrest cover than whats on the list, any ideas?
Old Jun 19, 2003 | 11:46 AM
Scoob's Avatar
Scoob
If you post your list here I will decode them all for you.
Old Jun 19, 2003 | 11:53 AM
86shark's Avatar
86shark
Default Re: Option codes (Scoob)
AC1 AC3 BGR AK5 AR9 V73 M30 JL9 KG9 HXO YAA U75 VM3 XAA IAY WA
There are more but did not have the time to finish writting them down, heck they might not even be codes, must have at least 15 more when I get back to the car.
Thanks :confused:
Old Jun 19, 2003 | 12:10 PM
Scoob's Avatar
Scoob
RPO Code Description
AC1 ADJUSTER, PASS ST, POWER, 6 WAY, BKT
AC3 ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
BGR BOWLING GREEN PLANT PROCESSING
AK5 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
V73 VEHICLE STATEMENT US/CANADA
M30 TRANSMISSION, AUTO 4 SPD, 4L60E
JL9 BRAKE, SYSTEM, PWR, FRT a RR OISC, ANTILOCK, FRT W
KG9 GENERATOR, 140 AMP
HX0 #N/A
YAA TIRE REAR, P285/40ZR17 BL R/PE ST TL HW4
U75 ANTENNA, POWER, RADIO
VM3 LABEL INFORMATION, CONSUMER, CONTAINS BPR IMP STANDARD FOR
XAA TIRE FRONT, P255/45ZR17 BL R/PE ST TL HW4
1AY ORDER MODIFICATION STOCK (ordered for dealer stock)
I'm not sure about the HX0 code. I'll keep looking.
When you get the chance post there rest and I'll help you out.
Old Jun 19, 2003 | 12:14 PM
86shark's Avatar
86shark
Wow you are fast, I can only imagine how fast your car is :lol: :lol:
Thanks for the info
To Option codes
