C4 Secrets???
Old Jun 24, 2003 | 03:38 PM
Bat Man's Avatar
Bat Man
Default C4 Secrets???
Are there any C4 secrets like the ones Scissors posted for the C5? http://forums.corvetteforum.com/zero...=589949&page=1
Old Jun 24, 2003 | 03:41 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Re: C4 Secrets??? (Valleybacker)
If so, I'd be interested as well.
Old Jun 24, 2003 | 03:54 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
I heard that c-4's have a chick magnet hid under the dash somewhere? :jester
Old Jun 24, 2003 | 04:15 PM
LT-4 CE's Avatar
LT-4 CE
Default Re: C4 Secrets??? (yoslambo1@cs.com)
I bought mine used - the original owner must of taken the chick magnet out and kept it or something. :lol:
Old Jun 24, 2003 | 04:59 PM
JSA 007's Avatar
JSA 007
St. Jude Contributor
Default Re: C4 Secrets??? (LT-4 CE)
-The little yellow "helper light" on the bottom of the rear-view mirror that illuminates the shifter area
I believe we established this feature in 86+
-That you can put your key in the driver's door and turn it twice towards the front to unlock the passenger door and a third time to pop the trunk.
Now that would be cool...but you can pop the hatch by using the button on the side of EITHER door as well as the "ejection" button in the center console.
-All of the option codes are in the glove box
Or some of us have them in the little compartments behind the driver. Also, you can lift up the tray in that compartment to reveal more storage.
-Tire inflation recommended pressures are on the driver's door
I believe ours are there too!
-The thing that looks like a little LED near the DIC buttons is a light sensor
The little square in the upper left corner of the DigiDash is a light sensor.
-If you pull the seatbelts all the way out while you're buckled in, they ratchet back in to hold you tighter into the seat.
If you push the Cinch button behind the e-brake, you can get it real tight!
-Simply remove fuse #2 under the hood and your DRLs will be out permanently. Only thing affected is that when you unlock at night using the key fob your front turn signal lights and back up lights will not will not flash. Your front turn signals will operate normally, however.
We don't have no stinkin' DRLs :lol:
-If you have the passive entry feature: If you lock your keys in the car, wait a few minutes and then shake the car. That will unlock the car.
I've heard stories of our PKE doing the same thing.
-You can easily shift the M6 trans up or down without the clutch if you match revs. (Not great for longevity, however.)
You can do that with any manual, but it's not recommended and you better be real good at matching the revs :lol:
-You can eject the cd from the in-dash player without turning on any power. Don't even need key in the ignition.
Yeah, that's pretty standard too.
-When the engine is shut off, you can get the odometer reading by turning on the parking lights.
Ummm, I don't have a digital odometer :D
I know you guys can think of others :cheers:
Old Jun 24, 2003 | 05:07 PM
GTrain's Avatar
GTrain
St. Jude Donor '14
Some Odd things on my C4 -
- The 6 speed transmission shields the oil plug so I can't get a socket on it.
- To open the car when its locked, the lock mechanism is the same on both sides, so on the driver side its toward the front, passenger toward the back
Bat Man's Avatar
Bat Man
Default Re: C4 Secrets??? (JSA 007)
I've got one, you can pull the compartment tray out of the back and get an even bigger storage bin.
Old Jun 24, 2003 | 05:10 PM
yoslambo1@cs.com
It also makes a great cooler! :jester
Old Jun 24, 2003 | 06:11 PM
SharkB4C4's Avatar
SharkB4C4
:lol: :lol: :lol: Mine's missing, too. Maybe I can buy one on eBay.
Old Jun 24, 2003 | 06:19 PM
SharkB4C4's Avatar
SharkB4C4
The lights above the handles on the door panels can be turned on by pressing in the forward edge (84-89 only, I think ... my 88 had it, my 96 doesn't.)
The armrests on 94-96 door panels flip open, and there are map pockets there.
Old Jun 24, 2003 | 07:25 PM
Billy's Avatar
Billy
Tip 1. When done washing I will spray the car off and then remove the nozzle to run a full stream of water which sheets off most the water thats usually beads up. This way I only need 2 towles to dry most any vehicle!!
Tip 2. Dont forget the secret compartment under the doors arm rests.
Tip 3. I,ve owned 8 C4s if you get the chance get the LT4 you,ll thank me!
Tip 4. on a 95 or 96 the chrome collector wheels look so much better
Tip 5. Dont drive with the top down and a hot blond in the pass. seat, because your car will get less attention.
Old Jun 24, 2003 | 07:38 PM
GTrain's Avatar
GTrain
St. Jude Donor '14
Default Re: C4 Secrets??? (Billy)
Tip 6. Get a shop vac with the romovable motor that doubles as a leaf blower. Zaino actually beads so well, that you can "wash and blow dry" and just towel off the little that is left. I then use Zaino spray to clean it up perfect.
Old Jun 24, 2003 | 07:40 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
We have plenty of those secrets, loook in the tech tips for reading codes with the A/C.
We can also open tEh hatch by pulling on a hidden cable.
To turn off the underhood lights, simply pull the fuse.
When you have a blown fuse, you will hear a buzzing sound when the door is open(at least in my '93 it did).
Old Jun 24, 2003 | 10:13 PM
Blue J's Avatar
Blue J
To change to battery, you have to remove the fender.
Old Jun 24, 2003 | 11:48 PM
CanadaVette's Avatar
CanadaVette
Old Jun 25, 2003 | 12:45 AM
chaos on wheels's Avatar
chaos on wheels
Hot dogs, apple pie, and Chevrolet just go together! Chevy embossed this into the fiberglas just above the passenger rear speaker on my 1990 convertible.
:flag
Old Jun 25, 2003 | 12:52 AM
Chefskeez6's Avatar
Chefskeez6
A compartment under the arm rests? Do i have those? 1992
To C4 Secrets???
Old Jun 25, 2003 | 01:04 AM
90 Corvette ZR-1's Avatar
90 Corvette ZR-1
--If you have the passive entry feature: If you lock your keys in the car, wait a few minutes and then shake the car. That will unlock the car.
Not always. One of the guys at the gathering locked his keys in his car. Not going to mention names. :D
Old Jun 25, 2003 | 01:06 AM
behnevette's Avatar
behnevette
I still have the chick magnet, but it's cancelled out by the chick repellent behind the steering wheel! :jester :jester
Old Jun 25, 2003 | 02:31 AM
linkschamp's Avatar
linkschamp
Default Re: C4 Secrets??? (chaos on wheels)
:flag
That's a fantastic secret! :thumbs:
I remember the summer that was a big-time advertising campaign! :flag
