I have seen you guys come up with answers on everything hope you can help. On my 93 I had a piece of rubber get caught into my secondary fan which caused my fuse to blow(don't know where that came from). When I cleared the blockage and made sure the fan spun freely I borrowed a the 20 amp fuse from the interior lights. When I got into the car to start it would not start. Removed the fuse put it back into its proper place and now have the door ajar light on and the interior lights will not turn off. Has anybody had a problem like this before? I believe the door switches are ok. I am going to start digging into this tonight and have the wiring diagrams but before I go to deep there may be a simple fix. Thanks
I thought the same thing bad switch, but I left the key on, opened the door and the chimes started ringing and I pushed the switch in and the chimes stopped and I tried this on both doors.
