Bose Stereo problem
Old Jul 29, 2003 | 10:06 AM
lakerat's Avatar
lakerat
Default Bose Stereo problem
On the drive in this morning, the Bose decided to take a break. Sound is there, but faint. Occasionally, it would jump to normal freq. Must be some kind of short. But where??
:confused:
Been planning on replacing this junk with something else anyway. Does anyone have suggestions on a "good fit" replacement for C4's?
Old Jul 29, 2003 | 10:17 AM
wicked_C4's Avatar
wicked_C4
Default Re: Bose Stereo problem (lakerat)
Last week I was looking at changing out my Bose system for a Kenwood dvd/mp3 player and found out that first of all the whole system would have to go. Can't just change out the head unit.
The cost to but in a decent system would start out at around $2000. I decided to get an adapter to run a 3rd party amp and hook up a single 10" JBL Sub in a custom box. Sounds pretty good and saved myself about a $1200. Don't think this situation helps you out if your Bose took a dump but it does let you know what price range you might be starting at.
Old Jul 29, 2003 | 12:20 PM
tempest's Avatar
tempest
from what you describe i'd first check the speaker amps located next to each speaker. there have been many posts in the past regarding diagnosing and repairing amps.
i replaced my system with decent speakers, no sub, no exernal amp, and a so-so head unit with MP3 play capability. ran me less than $500 but it sounds a helluva lot better than the stock setup.
good luck. :cheers:
Old Jul 29, 2003 | 12:30 PM
Charlutz's Avatar
Charlutz
post this in the audio forum with your budget. you'll get the advice you need there. $500 will outdo the bose spectacularly.
Old Jul 29, 2003 | 02:51 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Bose Stereo problem (Charlutz)
It sounds like one of your amps has tanked. You can remove them yourself, then have them repaired for around $65 each at:
http://www.doctordons.com/boseradios.htm
-OR-
http://www.carstereohelp.com/
[Modified by onedef92, 2:52 PM 7/29/2003]
Old Jul 29, 2003 | 03:21 PM
lakerat's Avatar
lakerat
Thanks all for the advice. Tonight, I'll check out the amps and the CDM. The "Best Buy" guy started sweat'in when I told him I wanted to switch out the Bose for something else. But, after reading all the post from Audio/Electrionics, I think I'll pay a visit to a "real" audio store. :)
Old Jul 29, 2003 | 05:25 PM
ljohn51's Avatar
ljohn51
If you have a convertible with speed volume increase check the lever behind the volume button and make sure it is either up or down- up(clockwise) is louder.
Old Jul 29, 2003 | 08:15 PM
tempest's Avatar
tempest
IMHO, don't discount the "unreal" audio stores if you are going to do the installing. i got my setup at circuit city and they actually gave me a "self install discount" of i think $30 (it's been a while so i don't remember the exact $$). they basically took out the cost of their "free" installation! the downside is that if you are after top-end stuff, they will probably not have it...
To Bose Stereo problem
