Tire Dressing
Old Aug 3, 2003 | 11:38 AM
Bob88Convertible's Avatar
Bob88Convertible
Default Re: Tire Dressing (Rex Ruby)
I use STP brand. Its the cheapest, last a week or so, and no buildup. :yesnod:
Old Aug 3, 2003 | 01:11 PM
BOB'S C6's Avatar
BOB'S C6
C6 of Year Finalist (stock) 2019
Default Re: Tire Dressing (Bob88Convertible)
:iagree:
STP Son of a Gun is better than armor all, doen't collect as much dust. But I clean the tires with Bleachy White about every other time I wash it ,that strips off any buildup.
Old Aug 3, 2003 | 07:59 PM
R23HTC's Avatar
R23HTC
Default Re: Tire Dressing (Midnite 88)
I use Maguires Gold Class Endurance. Comes with an applicator. Last a few weeks. Smells good. Leaves a semi-gloss shine or a gloss shine depending on how you use it.
Mike.
:iagree:
Old Aug 3, 2003 | 11:18 PM
91C4's Avatar
91C4
Default Re: Tire Dressing (R94 LT 1)
I use a $1.79 can of silcone spray from Wal Marts on the tires and weather stripping. It's easy and protectes the rubber from drying out.
Old Aug 4, 2003 | 01:29 AM
mitymek's Avatar
mitymek
duragloss foaming tire cleaner here.
spray it on,walk away from it.it dries .
no rags are bending over :)
i spray it up into the wells too,right over the dirt.looks good.
it has a nice pattern to the spray that makes it easy to use without hitting the rims (well not much of em)
Old Aug 4, 2003 | 09:02 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I use some stuff made by Eagle..I spray it on an old sponge and apply it that way...no splatter problems...I let it dry overnight and I don't recall it rubbing off on my pants...I don't recall bunking into the tires either though... :D
Old Aug 4, 2003 | 10:42 AM
DanielC485's Avatar
DanielC485
I use a generic foamer from the dollar store. Works just as good as the armor all foamer. The spray type does nothing for me. You just spray the foam on the wheels and walk away and you've got a good shine for a fair amount of time.
Old Aug 4, 2003 | 04:35 PM
CanadaVette's Avatar
CanadaVette
Default Re: Tire Dressing (Sprongs)
I use this stuff called magic 2000
They sell it at Canadian tire. (in Canada)
Old Aug 4, 2003 | 05:26 PM
Mikez40's Avatar
Mikez40
Default Re: Tire Dressing (redwing76)
If you don't like the high gloss looks of tire dressings and want the natural nice orignal black look. Just wash your tires with an SOS pad, (yes the same SOS pads that you would use to wash your pots and pans with). They will look like brand new tires when you are finished.
Old Aug 4, 2003 | 05:35 PM
HapAFcop's Avatar
HapAFcop
Default Re: Tire Dressing (Mikez40)
I normally use the foamy no touch stuff, but I've been wanting to try something different. Yesterday, I picked up some Black Magic Tire Wet. It has two application methods, one for high gloss and one for low gloss. I tried the high gloss method of the wife's Jeep and the low gloss on the vette. Both look good.
So far, I like it and would recommend. It smells like cherries, too :jester
Old Aug 4, 2003 | 07:25 PM
don hall's Avatar
don hall
Default Re: Tire Dressing (HapAFcop)
.....Black Magic Tire Wet.....I tried the high gloss....
It is recommended that you wipe off the excess from the tire now, rather than from the vette later. Also, if you have read several posts in this thread, the gel just loves jeans. It seems to jump right off the tire, if you get close. Keep a drop cloth handy to cover the tires..........
[Modified by Oldman, 4:27 PM 8/4/2003]
Old Aug 5, 2003 | 01:13 PM
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Tire Dressing (AllDreamsAreRed)
I use the High Endurance by Meguiar's too. Just don't gob too much of it on there and you won't get tire sling. :nono:
Old Aug 5, 2003 | 04:37 PM
  #33
QuikZilver's Avatar
QuikZilver
Default Re: Tire Dressing (91C4)
:iagree:
I have also used good old fashion baby oil if you want a nice shiny finish. It is really cheap! And it lasts a while. Doesn't take a lot. Just wipe it on and you are done. If you use a lot, you will sling it off the tires, but with the baby oil, just a touch goes a long way.
:seeya
Old Aug 5, 2003 | 04:57 PM
  #34
Steel Blue 91's Avatar
Steel Blue 91
I'm a big fan of AP303. Leaves a low gloss, natural rubber look and last from wash to wash. Just spray it on, let it sit and wipe off the excess. The only down side is that it's a little pricey if you buy small quanties. I bought a gallon 1.5 years ago and still have it. I use it on the interior as well.
Old Aug 5, 2003 | 06:45 PM
  #35
Eric 96's Avatar
Eric 96
Endurance :thumbs:
Old Aug 6, 2003 | 10:52 AM
  #36
pkvvette's Avatar
pkvvette
Default Re: Tire Dressing (Eric 96)
Turtle Wax Wet n Black. Also use one of those round plastic shields while spraying to keep it off the wheels. I use a 36" x 16" piece of plastic plate with the exact tire footprint cut out of it to keep the overspray off the driveway. That stuff does not wash away!
