87 coup hardtop removal problem
Old Aug 3, 2003 | 10:23 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default 87 coup hardtop removal problem
Hi, new vette owner 1st one. Problem is: 1st: hardtop frame is broken, section missing @ windshield and trying to remove hardtop to replace weatherstriping and replace with new frame or top.. can remove back bolts and top moves but cannot get the front to release to remove...
Any info on how to remove top would be greatly appreciated... Help..
Old Aug 3, 2003 | 11:35 AM
offershore's Avatar
offershore
Default Re: 87 coup hardtop removal problem (daddvi)
search my post's about two week's ago I had a simular problem. Someone sent me a very good set of instructions, you'll need them for your new top too!
Old Aug 3, 2003 | 04:25 PM
vinnies87's Avatar
vinnies87
Default Re: 87 coup hardtop removal problem (offershore)
Thanks for the reply... did look and could not find, could you email me the post ? Would be much appreciated... thanks
Old Aug 3, 2003 | 08:12 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you using the G.M. supplied ratchet to remove the 4 TORX bolts(2 front 2 rear)
There is a hole in trim by visor on both sides.
In that hole is the torx bolt.
If you realize that than disregard my comments and give the roof a good yank!! :D
Old Aug 3, 2003 | 08:35 PM
offershore's Avatar
offershore
Sorry my fault, it's not there.He faxed it to me or e-mail? Anyway he's a good guy and here's his add. scoob@naturalglasscorvette.com he'll be glad to help. again sorry about that :banghead:
Old Aug 4, 2003 | 12:15 AM
vinnies87's Avatar
vinnies87
Default Re: 87 coup hardtop removal problem (AGENT 86)
Thanks,,, and i didn't know about the two front bolts... would be a good reason as to why the front would not move... should make replacing the weatherstrip alot easier... Thanks for the info...
To 87 coup hardtop removal problem
