Help! Need to know...
Aug 4, 2003 | 10:25 PM
if the flat part of the rear lower control arm, (goes from the center of the diff to the lower part of the rear knuckle) goes on top or bottom. The manual shows it as going on the bottom.
This part also sets the rear camber.
TIA Mike.
Aug 4, 2003 | 10:32 PM
Re: Help! Need to know... (Midnite 88)
Yes, bottom. Looks like an upside-down 'T'... on my 95.
Aug 4, 2003 | 10:39 PM
Re: Help! Need to know... (Sun King)
Thank you! I thought that it was correct but, after I changed the bushings in it, it was kind of hard to get back in.
Mike.
Aug 4, 2003 | 10:49 PM
Did you do one side or both? those rod are left and right, the part# is the same on both though. Don't ask how I know that :crazy:
Aug 4, 2003 | 10:56 PM
Re: Help! Need to know... (offershore)
I did both sides and there is lettering "LH" and "RH" on them. I'm pretty sure, acutally I'm positive that I got them back on the correct side.
When I took the parts off to do the bushings, I layed all the left side parts on the left side of the car and vise versa.
I wish I had a digital camera, I polished or painted just about everything that I took off.
Thanks again,
Mike.
[Modified by Midnite 88, 10:57 PM 8/4/2003]
