Front Speakers removal, need help
Old Sep 8, 2003 | 11:43 PM
1987Vetter's Avatar
1987Vetter
4th Gear
Default Front Speakers removal, need help
Ah...maybe a dumb question, but how do i remove the front speakers to replace them? Was gonna put Infinity 4x6's..(i think that is the stock size) in their place, but I'm not sure if i have to just remove the covers, or if i have to remove the dash. :confused: Also, i just ran a power wire for a 300 watt amp to the battery, is there anything else i have to do or should i be ok just running a 10 gauge wire with in-line fuse directly to the amp from the battery? thanks for any replys. :rolleyes:
Old Sep 9, 2003 | 12:18 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Front Speakers removal, need help (1987Vetter)
You have to remove the dash pad to replace speakers.
I would think that 10 gauge wire would be fine for amp.
:cheers:
Old Sep 9, 2003 | 12:33 AM
Cory00's Avatar
Cory00
i think they are 4 inch but i may be wrong
10 to 8 will be just fine :cheers:
To Front Speakers removal, need help
By Michael S. Palmer | 2026-06-03 11:00:24
