4+3 shift pattern
Old Sep 12, 2003 | 12:37 PM
billschau's Avatar
billschau
Cruising
Default 4+3 shift pattern
I'm almost embarrassed to ask, but what is the normal procedure of running the gears? Do you run the straight 1-4 and fill in with od as needed or doyou run each gear with the split.
Old Sep 12, 2003 | 02:19 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
Default Re: 4+3 shift pattern (billschau)
Run in whatever gear suits you and the rev range you like to run in.
I personally like 2nd OD around town where I can boot it and kick down to waste nasty ricers. JMO. :steering:
Old Sep 12, 2003 | 05:40 PM
Q1KSLVR's Avatar
Q1KSLVR
1 - 2 - 3 - 4
Then push the button for 5th.
You can push the button in other gears, but I only did if I was cruising. As long as you remember to turn it off before you stop, because as soon as you hit 2nd, it will slam it into OD and bog....
Just experiment and have fun with it....
Old Sep 12, 2003 | 07:20 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Around town, it's 1 2 3 4. When I hit the hwy, 50+ mph I clutch it, turn on the overdrive and stay with that, till I'm back down to city, 45mph or less. :yesnod: And do yourself and your OD a favor, clutch going in, and clutch going out. Unless you kick it down to burn ricers :lol:
Old Sep 12, 2003 | 07:21 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Default Re: 4+3 shift pattern (ductape)
Excuse me, I mean waste nasty ricers ..... :lolg:
Old Sep 12, 2003 | 07:27 PM
scorp508's Avatar
scorp508
1-2-3-4 then 4OD on the highway.
Lower OD gears are used for setting the bait for prey.
:reddevil
To 4+3 shift pattern
