Brake lights not working
Old Sep 20, 2003 | 08:13 PM
rebuild's Avatar
rebuild
Default Brake lights not working
I have a'93 coupe and the brake lights aren't working. the tail lights are fine. I changed the switches but the still don't work. Anyone have any ideas what could be wrong? It's pretty aggrevating under the dash.
Old Sep 20, 2003 | 09:17 PM
HapAFcop's Avatar
HapAFcop
Default Re: Brake lights not working (rebuild)
Make sure you changed the right switch. There are two, which look similar, attached to the brake pedal. One is for the brake lights and the other for the cruise control.
Do a search for "brake lights". There's lots of info. I recently had to fix my 3rd brake light to pass state inspection and found all the info I needed on the forum.
Old Sep 20, 2003 | 09:37 PM
rebuild's Avatar
rebuild
Default Re: Brake lights not working (HapAFcop)
I changed both switches it came as a set but still no lights.
Old Sep 20, 2003 | 09:39 PM
Southern Comfort's Avatar
Southern Comfort
Have you checked the bulbs....not likley all 4 will go out but this is a Corvette...expect the unexpected.... :lol:
Old Sep 20, 2003 | 10:29 PM
rebuild's Avatar
rebuild
Default Re: Brake lights not working (Southern Comfort)
The center light isn't working either.
Old Sep 21, 2003 | 01:30 AM
rebuild's Avatar
rebuild
I just noticed that the hazard lights aren't working either, but both turn signals do, what do you think?
Old Sep 21, 2003 | 02:15 AM
Southern Comfort
Maybe the hazard flasher? Buried in the dash :sad:
To Brake lights not working
