injector?
Old Nov 3, 2003 | 02:36 PM
packinair's Avatar
packinair
From: Wanna join CFOT TeamLeghumper? Email cfotteamleghumper@gmail.com w/your forum name oh
Default injector?
I tumned up my 85 with plugs,wires,cap and rotor and #6 is not firing well . I replaced again the wire and plug and cap. it is still missing really bad in that cyl. injector or what else to check?? is there a cheep way to check cause I am poor?
Old Nov 3, 2003 | 07:03 PM
Midnite 88's Avatar
Midnite 88
Default Re: injector? (packinair)
How do you know that it is the #6 cylinder that is not firing?
Have you checked to see if you have spark going to that cylinder?
Have you unplugged the injector while running to see if there is a difference?
If you need help diagnosing the problem, shoot me an E-mail and let me know what you have already done. Maybe I can be of some help.
Mike.
Old Nov 3, 2003 | 08:33 PM
packinair's Avatar
packinair
Default Re: injector? (Midnite 88)
I pulled off all the wires 1 at a time and found that with #6 off it runs the same as if it was on.. I even took it around the block with the wire off and no change from when it was on. so I replaced the new wire plug and new cap again. I checked for spark with another plug witht he car running at that hole had good fire. that is what is leading me to the injector? also did a compression test and it was about 135 so that leads ME to believe that is is spark or fuel and I have elimiated spark (I think)
Old Nov 3, 2003 | 09:44 PM
Midnite 88's Avatar
Midnite 88
Packinair, I sent you an E-mail.
Mike.
Old Nov 3, 2003 | 09:53 PM
Siveck's Avatar
Siveck
The #6 injector on my '89 went down and caused some problems last year. It turned out that the resistance in the injector had broken down so that it would not function. They should read at about 16 ohms each. #6 read at about 5 ohms or so.
Old Nov 3, 2003 | 11:37 PM
packinair's Avatar
packinair
Default Re: injector? (Siveck)
I was also looking into pulling them out and having them cleaned.. anyone ever do this?
Old Nov 5, 2003 | 08:46 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Run a leak down test. Or a compression test on the cylinders. Burning any oil?
Good Luck.
To injector?
