96 LT1 Evap System Problems
Old Nov 24, 2003 | 11:09 PM
jay'szo6's Avatar
jay'szo6
Default 96 LT1 Evap System Problems
I just bought my first vette. I just replaced the evap soleniod and the evap canister. :mad Which could've been avioded probably if I found the real root of the problem. The code was PO1441. Any advice would be highly appreciated. thanx. :flag
Old Nov 24, 2003 | 11:31 PM
Blk-94's Avatar
Blk-94
Default Re: 96 LT1 Evap System Problems (1nicec4)
Same here.. Wife's 96 is having the same issue. It was suggested to replace the gas cap.. Did that, code cleared for awhile but came back after she filled up the last time. So must have something to do with that.
I'm not having any luck with the C4's lately.
Old Nov 25, 2003 | 02:03 AM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: 96 LT1 Evap System Problems (Blk-94)
If you guys are filling up with the car running, it will set that code. (if it runs that test at that time)
Or, if you aren't getting the cap on tight.....
Hope that helps! :thumbs:
Old Nov 25, 2003 | 10:37 AM
Blk-94's Avatar
Blk-94
Default Re: 96 LT1 Evap System Problems (Q1KSLVR)
For me.. Dunno.. Wife unit drives that car and fills it up.. I'll ask her about it. Soooo.. If I turn up missing... :D
Old Nov 28, 2003 | 06:04 PM
Bluestrat's Avatar
Bluestrat
5th Gear
I had the same problem on my 96 and found the problem to be the valve that is back by the cannister its is about a $40 part. It looks like a tophat has a vacuum line from the gastank and feeds into the canister. I replaced one part at a time starting at the throttle body but should have started at the tank. I think they get flaky and start to leak around the seal. Code read something like no vacuum on purge and started intermittent but got to be a frequent flyer so I fixed it.
Old Nov 29, 2003 | 01:22 PM
jay'szo6's Avatar
jay'szo6
Today i get in my car vette to go to work, and the service soon light's not on. I had it reset the other day, and it came on that night. I've put gas in since. I made sure to screw the gas cap on extra tight. Hope fully it stays off for good. :chevy
Old Dec 2, 2003 | 06:58 PM
jay'szo6's Avatar
jay'szo6
Well, after a few days of driving the light came back on. WHAT A BUMMER!! :mad I think the light stayed off because it's been cold outside where I live. But today is the warmest day we've had lately. :confused: At this piont, i'm stumped!! Anymore feed back would be great. :flag
Old Apr 6, 2010 | 02:35 PM
96_vette's Avatar
96_vette
I just pulled PO1441 fault code today on my 96 LT1. I will look into the canister and the gas cap seal!
Old Apr 6, 2010 | 10:19 PM
96GS#007's Avatar
96GS#007
99 times out of 100....
ACDELCO Part # 214565
VALVE,Evaporative Emission Canister PURGE SOLENOID 2 PORT VAC-2 BLADE TERMINAL
Located on the right side of the intake manifold.
Simple test: Remove the two vacuum hoses. Remove the electrical connector. Blow air thru either port on the solenoid. If the air passes freely, the solenoid is bad.
Old Apr 6, 2010 | 11:09 PM
96_vette's Avatar
96_vette
Awsome.Thanks for such a informative post!! I owe you beer!
Old Apr 6, 2010 | 11:30 PM
surfer92's Avatar
surfer92
Check vacuum lines, ths is one reason the FSM is worth the $100 price tag.
Check solenoid connector for broken wires or dirt inside the connector.
Old Apr 9, 2010 | 08:59 PM
96_vette's Avatar
96_vette
Ok pulled purge solenoid, air passes through it freely. Bought a new one and put it on, then pluged in my OBD-II tool and erased the fault code: P1441. Have not drove car since I cleared the code. Will post what happens!!
Old May 1, 2010 | 12:24 PM
jkr1100's Avatar
jkr1100
3rd Gear
This fixed mine. My Solenoid tested bad as described above. $53 at local chevy dealer. 7mm socket to remove bracket. i have a 1996 LT1 convertible. 5-1-2010 The GM part number is 1997201.
Old May 1, 2010 | 09:01 PM
surfer93's Avatar
surfer93
Did the new solenoid fix the problem??
The world wonders!!
Old May 2, 2010 | 10:54 AM
wnafly's Avatar
wnafly
Old May 4, 2010 | 03:39 PM
jkr1100's Avatar
jkr1100
3rd Gear
The world wonders!!
The words "This fixed mine" threw you off? YES, the "world" can stop wondering?
Old May 4, 2010 | 07:17 PM
tblt44's Avatar
tblt44
I just replaced that same part (Evap solinoid) on my wife 2006 Tahoe because of the service engine soon light.This was also replaced under warrenty 3 years ago.These do go bad,I have my third one on a 2006 Tahoe now.
To 96 LT1 Evap System Problems
