96 keyless entry
Old Nov 28, 2003 | 08:32 AM
silver96lt4's Avatar
silver96lt4
1st Gear
Default 96 keyless entry
I'm having problems with my alarm.The key fob is unlocking the passenger door and the rear hatch but the alarm won't automatically set itself when I walk away and have to use the key to open the drivers door.Where is the alarm system and what would I check?
Old Nov 28, 2003 | 09:11 AM
HTRK-1's Avatar
HTRK-1
Default Re: 96 keyless entry (silver96lt4)
Sounds like your PKE is disabled. Stand next to the driver's door and hold the door button on the key fob (hold for about 10-20 seconds) the door locks will cycle. Now your system should work properly. This same procedure works to disable it. Hope this helps
Old Nov 28, 2003 | 07:28 PM
Teh Nam's Avatar
Teh Nam
Default Re: 96 keyless entry (HTRK-1)
:iagree:
Old Nov 28, 2003 | 08:27 PM
Stv50's Avatar
Stv50
I have found that if you stand just to the right of the drivers door and back a few steps and hold the button down and let it cycle it should reset.
To 96 keyless entry
