keyless entry
Old Nov 29, 2003 | 11:17 AM
jobberone's Avatar
jobberone
jobberone
Default keyless entry
What's best options for putting keyless entry on 89 driver? Thanks in advance. Michael
Old Nov 29, 2003 | 11:32 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: keyless entry (jobberone)
:lurk:
Old Nov 29, 2003 | 11:34 AM
jobberone's Avatar
jobberone
jobberone
Default Re: keyless entry (brdd)
I assume this means you can't
Old Nov 29, 2003 | 05:18 PM
brdd's Avatar
brdd
no....it means I don't have a clue and I hope someone with a clue replies.... :yesnod:
Old Nov 29, 2003 | 06:01 PM
jobberone's Avatar
jobberone
jobberone
Thanks for your time. :cheers:
Old Nov 29, 2003 | 06:25 PM
SPEED750's Avatar
SPEED750
Try a search on this one. I think you need a VKE-100 it's a GM keyless entry that cost about $100. :chevy
Old Nov 29, 2003 | 06:27 PM
jobberone's Avatar
jobberone
jobberone
Default Re: keyless entry (SPEED750)
Thanks very much. I looked around a bit but never found anything useful. Thanks again. Michael
Old Nov 29, 2003 | 07:03 PM
Spinman's Avatar
Spinman
http://www.batee.com/corvette/keylessentry/index.shtml
Old Nov 29, 2003 | 11:21 PM
shotchkiss's Avatar
shotchkiss
Sending an email your way soon.
Old Nov 30, 2003 | 12:05 AM
jobberone's Avatar
jobberone
jobberone
Default Re: keyless entry (Spinman)
Thanks Spinman.
Old Nov 30, 2003 | 06:58 PM
jobberone's Avatar
jobberone
jobberone
Default Re: keyless entry (shotchkiss)
Thanks to you as well shotchkiss
Old Dec 2, 2003 | 11:21 AM
merplastic91's Avatar
merplastic91
anyone know if a remote starter would work as it includes the doors and go for about $50 bucks at many of the electronic retailers?
Old Dec 2, 2003 | 06:17 PM
jobberone's Avatar
jobberone
jobberone
Default Re: keyless entry (merplastic91)
don't know but I'd like to have that as an option. However doubt it will work on manual transmission cars as you would have to leave it in neutral and somehow bypass the clutch depression switch to start the vehicle. Shouldn't be as big a deal in AT cars tho. Good luck, Michael
Old Dec 2, 2003 | 08:07 PM
JasonL's Avatar
JasonL
Safety issues aside, I don't think it would be difficult to install remote start on a manual tranny. You would need to leave the car in neutral, bypass the neutral safety switch, and bypass the VATS with a fixed resistor (also required for autos).
Old Dec 2, 2003 | 08:14 PM
jobberone's Avatar
jobberone
jobberone
Default Re: keyless entry (JasonL)
Would you have to remove the neutral start switch?
Old Dec 2, 2003 | 08:24 PM
JasonL's Avatar
JasonL
I don't think so. I would need to see the schematics, but you could:
1. Permanently short the two wires (not as safe, and may have cruise control shut-off issues??)
2. Use a relay to short the wires only when using the remote start (safer because it retains functionality when using the regular key)
Old Dec 2, 2003 | 08:52 PM
jobberone's Avatar
jobberone
jobberone
Interesting. Always good to hear fresh ideas. :cheers:
To keyless entry
Old Dec 2, 2003 | 10:33 PM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
I'd like to have keyless entry on my '89 also. (Maybe for Christmas)
Can you send the email my way too?
383c4@swko.net
[Modified by X-FireChance, 9:34 PM 12/2/2003]
Old Dec 2, 2003 | 10:55 PM
Spinman's Avatar
Spinman
And now for another point of view - - Here's GM Position:
Alarm / Keyless Entry - Aftermarket Installatin Cautions
Bulleting 93-23-9J
October, 1992
Model and Year: 1986 - 1993 Corvette
Due to the complexity of the Corvette's electrical system, Chevrolet dealers should not install or recommend the after-market installation of an additional secuiryt system or a keyless entry system.
The Corvette is equipped with two security systems, Universal Theft Deterent (UTD), and the PASS-KEY system. These systems have proven to be very effective in deterring thefts. There is no need for an aftermarket security system.
Also, the 1993 Corvette is equipped with the Passive Keyless Entry (PKE) which interfaces with the UTD system. These systems are highly integrated and the addition of any after-market components may interfer with the UTD and PASS_KEY security systems or the operation of other Corvette electrical systems, causing customer dissatisfaction.
THE INSTALLATION OF AFTER-MARKET SECURITY SYSTEMS AND KEYLESS ENTRY SYSTEMS COULD RESULT IN DAMAGE TO THE VEHICLE AND COULD VOID PORTIONS OF THE VEHICLE WARRANTY.
Old Dec 3, 2003 | 12:03 AM
Chance's Avatar
Chance
St. Jude Donor '08
That's interesting, but I highly doubt that any part of my car is still under warranty. :D
