Lightest C4
Old Dec 1, 2003 | 11:04 PM
CORVETTE GURU's Avatar
CORVETTE GURU
Default Lightest C4
What is the lightest Factory (non special order) COUPE corvette?? ;)
Old Dec 1, 2003 | 11:51 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Default Re: Lightest C4 (CORVETTE GURU)
I voted for the 1986 based upon your choices - We all know that the C4 got rather bloated over the years and ZR1's were a bit more portly than a base C4 :leaving:
Old Dec 1, 2003 | 11:59 PM
wmrobert's Avatar
wmrobert
1984 C4 weighed 3192 lbs. The next lightest was 1995 at 3209 lbs. So much for the poll. :)
Old Dec 2, 2003 | 12:06 AM
*89x2*'s Avatar
*89x2*
Default Re: Lightest C4 (wmrobert)
I would have figured the 84 to wiegh a bit more, decent ;)
BTW - Nice avatar - Are you a Callaway enthusiast?????????
Old Dec 2, 2003 | 10:56 AM
vettefast's Avatar
vettefast
1990 ZR1 was the lightest of all the ZR1s! They went out of there way to knock down the weight on this car.
Old Dec 2, 2003 | 05:08 PM
redfast's Avatar
redfast
Default Re: Lightest C4 (vettefast)
Early C-4s were lightest out of the C-4 generation. :steering:
Old Dec 2, 2003 | 05:25 PM
85RIT's Avatar
85RIT
The title for my 85 says 3187? Thats a bit lighter then both...unless the title lies.... :rolleyes:
Old Dec 2, 2003 | 05:44 PM
DarkRed95's Avatar
DarkRed95
The automatic for 1984 was 3192 and manual was 3164.
The 1995 automatic was 3309.
The next lightest is 1989 3223 for automatic versions.
These are curb wieght.
Old Dec 3, 2003 | 02:09 PM
scorp508's Avatar
scorp508
1987 Coupe, look it up. :yesnod:
Old Dec 3, 2003 | 02:10 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Whoo-hoo I own the lightest, least powerful C4 :hurray:
Old Dec 3, 2003 | 02:31 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
I weighed my 87 when it was stock, w/o jack, spare tire and visors, came out to be 3160 w/ all fluids full. Just add whatever weight you feel is reasonable for the missing items and that's what my 87 auto coupe weighs.
Old Dec 3, 2003 | 02:32 PM
DarkRed95's Avatar
DarkRed95
Default Re: (scorp508)
According to my Corvette Spec book :
Coupe curb weight is 3229 with standard equipment.
Old Dec 4, 2003 | 02:40 AM
wmrobert's Avatar
wmrobert
Default Re: Lightest C4 (DarkRed95)
According to "Corvette Black Book" C4 coupe curb weights were as follows:
1984, 3192; 1985, 3224; 1986, 3239; 1987, 3216; 1988, 3245; 1989, 3238; 1990, 3288; 1991, 3288; 1992, 3338; 1993, 3333; 1994, 3309; 1995, 3209; 1996, 3298. That would make the 1984 the lightest and the 1992 the heaviest.
Another interesting bit of trivia: The 1984 through 1991 C4 coupes were 46.7" high and the 1992 through 1996 were 46.3" high. C5's are 47.8" (until 2002 when they shrunk to 47.7") :lol:
Old Dec 4, 2003 | 09:29 AM
vettefast's Avatar
vettefast
Default Re: Lightest C4 (flannel_man)
:lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :cheers:
Old Dec 4, 2003 | 10:45 AM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Does anyone know WHY the 84 is the lightest? What DOESN'T it have that all the rest do? Thanks...
[Modified by tobijohn, 10:45 AM 12/4/2003]
Old Dec 4, 2003 | 06:59 PM
RED-85-Z51's Avatar
RED-85-Z51
Default Re: Lightest C4 (tobijohn)
Well, 1984-85 dont have the extensive ABS pump and wiring, nor do they have the Air Bags....Or an ASR system...hmmm
I remember seein the 84-85 being much lighter than the 86-96 models...?
oh and the 84 lacks the pure raw unbridled HP and Torque found in the 85-present models...but a 84 Z51 will kill in the auto cross.
Old Dec 4, 2003 | 07:42 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
..........no frisbee?.......... :leaving:
To Lightest C4
Old Dec 5, 2003 | 03:32 AM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: Lightest C4 (brdd)
I have you guys ALL BEATEN!
The 1987 (?) B2K option was the lightest!
It came from the factory without an engine!
:p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p: :p:
[Modified by Q1KSLVR, 3:33 AM 12/5/2003]
Old Dec 6, 2003 | 02:11 AM
MrSpeedyBob's Avatar
MrSpeedyBob
Why don't I see weight drops coresponding to the
1) switch from iron to alum heads on the L98? (not sure of year)
2) L98 to LT1 switch? The LT1/4 is an alum block right? (91 to 92)
[Modified by rkessel, 7:12 AM 12/6/2003]
Old Dec 6, 2003 | 02:25 AM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: Lightest C4 (rkessel)
Heads won't make a very big weight drop..... the newer the car, the more crap they have hang off of them... just look at the difference between '95-'96.... the only difference is the OBDI and OBDII......
LT-1/4 have iron blocks.....
