Fan not working.....
Old Dec 9, 2003 | 11:32 AM
vickfalcons78's Avatar
vickfalcons78
5th Gear
Default Fan not working.....
I have a 1984 corvette and my fan isn't turning on when needed and my car is over heating regularly. I already checked the fuse pannel for a bad fuse but that wasnt the problem. If anyone has any information please reply to this note. Thanks :mad :mad
Old Dec 10, 2003 | 04:39 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Default Re: Fan not working..... (vickfalcons78)
Does the fan turn on at all...What temp are you calling overheating?
Old Dec 11, 2003 | 11:14 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
try putting in diag mode and see if you fan turns on, or you could try direct 12v from the batter to the fan bypass in relay to see if it runs...if it does, then prob the relay, and try just turning the fan by hand to make sure it rotates...
Old Dec 13, 2003 | 11:19 AM
redwing76's Avatar
redwing76
Default Re: Fan not working..... (vinnies87)
The man knows HOT. :iagree:
To Fan not working.....
