Flex hoses
Old Dec 10, 2003 | 08:44 PM
efweber's Avatar
efweber
Default Flex hoses
I am going to be installing new brake pads, rotors, and flex hoses this winter on my 1984 Corvette. I have the parts, but I think I need to buy a set of brake line wrenches. Does anyone know what size the brake lines are on my car?
Old Dec 11, 2003 | 11:11 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Flex hoses (efweber)
Brakes: 15,17 mm, 13/16 combo... I use the 13/16 on the caliper mounting bracket, their metric but it fits really tight, so no change of stripping the head... also.. buy a good set, snap-on, etc... tighter tollerances... :thumbs: :thumbs:
Old Dec 12, 2003 | 05:47 PM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: Flex hoses (vinnies87)
:rolleyes: UUUMMMMMM he said LINE WRENCHES! for the BRAKE LINES! I can't remember off hand, but Sears sells a good set of line wrenches.
I use Craftsman all the time. :thumbs:
Old Dec 12, 2003 | 05:50 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Are you going to use the crossdrilled or slotted rotors?
thanks
tony
:flag
Old Dec 12, 2003 | 07:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Sorry I don't know the hose sizes but can offer some suggestions on that brake job, if you don't mind.
When installing pads you need to install new clips, caliper pins & C-clips and coat the back of the pads with an anti-rattle compound.
When the calipers are removed you need to install new caliper bolts & washers. The new bolts come with red threadlocker applied.
You will also need a torque wrench to install the caliper bolts.
[Modified by 65Z01, 8:06 PM 12/12/2003]
Old Dec 12, 2003 | 07:59 PM
efweber's Avatar
efweber
Default Re: Flex hoses (oldace84)
thanks
tony
:flag
I bought a kit from VBP that includes slotted rotors, pads, stainless steel flex hoses, and brake fluid. I probably would not have gone with this equipment, but it turned out to be just as cheap as OEM, so I figured I might as well go with better parts. I should mention that my Corvette has 183,000 miles, and is a work in progress.
Old Dec 12, 2003 | 08:10 PM
efweber's Avatar
efweber
Default Re: Flex hoses (65Z01)
Any suggestions on where to buy those parts? I gotta go-I'm watching the Corvette items on QVC.
Old Dec 12, 2003 | 08:14 PM
65Z01's Avatar
65Z01
I got the caliper bolts & washers from my local Chevy dealer; the other parts should be available from a local brake parts dealer, of the Chevy dealer.
Old Dec 13, 2003 | 11:25 AM
1990CORVETTE's Avatar
1990CORVETTE
:lurk:
To Flex hoses
