Squeaky Suspension
Old Jan 10, 2004 | 05:15 PM
RED-85-Z51's Avatar
RED-85-Z51
Default Squeaky Suspension
Hey, Ive got a squeaky front suspension. It of course only makes the loud squeak over speed bumps, and on rough roads.
Im just wondering if it might be the front shocks. It came wih rebuildable O.E. Bilsteins, but I didnt know it, and had them replaced with 19.99 Gabriels..lol..FRIKKEN PEPBOYS!!...
How can I figure out if its the Bushings or the shocks? The bushings look ok from what I see. But its a really loud squeak..I mean louder than the exhaust...heh
Tommy, 8T5Z51, in Fl..
Old Jan 10, 2004 | 08:44 PM
greg84's Avatar
greg84
Default Re: Squeaky Suspension (RED-85-Z51)
hi,sounds like your a frame bushings might be bad.spray some silicone spray on one a -frame at a time and try the bounce test and see if the noise goes away and then you found the one that needs the bushings.good luck greg84 :cool:
Old Jan 10, 2004 | 10:31 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
I have never heard shocks squeak. It's the bushings.
Also check to make sure your transmission cooler lines aren't touching. Mine were and made an embarassing squeak for over 6 months before I figured out what it was. All it took to fix was bending the lines apart.
[Modified by flyersfan1088, 9:33 PM 1/10/2004]
Old Jan 10, 2004 | 10:40 PM
Z51JEFF's Avatar
Z51JEFF
ITS EATHER THE A ARM BUSHINGS OR THE SPRING IN THE SPRING POCKETS IN THE A ARMS.LOOK IN THE LOWER A ARM AND YOU WILL SEE THE RUBBER ON THE END OF THE SPRING.
Old Jan 11, 2004 | 03:59 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Squeaky Suspension (z51jeff)
It's the bushings. Mine was quiet as can be until getting on some dirty roads, mud and freezing conditions. Now it squeaks like an old fat man's shoes.
You just need to keep it lubed up. Put er up on blocks and spray on some dry lubricant, like silicone spray.
Old Jan 12, 2004 | 03:07 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Squeaky Suspension (CentralCoaster)
:iagree: :thumbs:
Old Jan 12, 2004 | 03:25 PM
JasonL's Avatar
JasonL
Default Re: Squeaky Suspension (vinnies87)
The sway bar mount bushings can also squeak, so don't overlook those.
Old Jan 12, 2004 | 04:05 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Squeaky Suspension (JasonL)
Mine Sqeaks really bad thanks for the info and common sence.....
:withstupid:
Old Jan 12, 2004 | 04:35 PM
96LT1's Avatar
96LT1
As has been suggested check your bushings on the control arms, the sway bar and the end links. How long have you owned the car? If the previous owner replaced the OEM bushings with polys, they have a tendency to squeek.
I installed polys on my 86 two years ago. Normally they don't squeek unless it gets cold or the car has been setting for awhile.
Old Jan 12, 2004 | 04:39 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Re: Squeaky Suspension (96LT1)
96LT1; Do you have a preferred lubricant?
:cheers:
JRC
Old Jan 12, 2004 | 04:47 PM
JasonL's Avatar
JasonL
Default Re: Squeaky Suspension (JrRifleCoach)
I'm not 96LT1, but I've successfully used the following (most preferable listed first)
grease that Energy Suspension includes w/ parts
wheel bearing grease (same stuff I use on ball joints)
white lithium grease
Heck, I've used vaseline before and it worked ok :D The silicone spray stuff is more of a stopgap when you can't easily remove the bushings.
Old Jan 12, 2004 | 07:18 PM
96LT1's Avatar
96LT1
:cheers:
JRC
I used the grease supplied until it ran out. Went to a local marine (boating) supply store and picked up a tube of marine grease. Lathered the bushings and the metal. Clean-up was a bit of a bear but it was worth it.
Old Jan 12, 2004 | 07:25 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
:withstupid: off to buy silicone :auto:
Old Jan 12, 2004 | 09:26 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Squeaky Suspension (flannel_man)
The problem in the early C4 is the squeeky frt suspension. It is in the monospring in front. but greasing, lubing, whatever to the mounts is temporary. What i found and was told, is that the spring breaks sometimes you cant se it. I replaced mine on a 84 (after doing everything else) and that was it. I believe it was $150 and pretty easy to install on a lift. That solved it. No more embarassment driving over the bumps at local shows. So if your spending money anyway, just get a new spring.
To Squeaky Suspension
