1985 Codes
Old Jan 26, 2004 | 02:25 PM
Darth Vader's Avatar
Darth Vader
Default 1985 Codes
My brothers 85' doesnt have the codes on the console lid.
Are they located any where else? How can you tell if you have a Z51 vette or
a G92 Axle?
Old Jan 26, 2004 | 03:04 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: 1985 Codes (Darth Vader)
Possibly the build sheet that glued to the gas tank.However,over time the papers crumple and fall,fade off etc.Its not easy to even read that from under the car because its usually glued to the tank out of sight.
There also suppossed to be a axle code tagged on somewhere at the rear end/axle.Cant remember exactly what it was,Im sure the others will post later.Btw,does the car have an Oil cooler?It would be a round box above the oil filter with 2 hoses coming out of it.I think thats another way to tell if it has the Z51 package unless Im mistaken.
Old Jan 26, 2004 | 04:26 PM
vader86's Avatar
vader86
Drivers' side compartment, there is a sticker there with codes.
otherwise the build sheet will have them
Old Jan 26, 2004 | 04:37 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: 1985 Codes (vader86)
:iagree:
Old Jan 26, 2004 | 05:03 PM
Vetterin's Avatar
Vetterin
Z51 has 9.5" wide wheels, regular has 8.5".
2.2 turns lock to lock on steering wheel for Z51, 2.7 turns for regular.
To 1985 Codes
