Jack it up!
Old Jan 29, 2004 | 12:07 AM
MrWiggly's Avatar
MrWiggly
From: Sunny Seaside Seabrook Texas (a whole 'nother country)
Default Jack it up!
It occurred to me today that I'm not familiar with the jacking points on the Vette. Any suggestions so I don't break stuff? TIA
Old Jan 29, 2004 | 01:14 AM
Wayne88's Avatar
Wayne88
Default Re: Jack it up! (MrWiggly)
As far as I know, there are 4 points under the rocker panels: They says "place jack here", or something like that.
:flag
Old Jan 29, 2004 | 03:50 AM
merrick's Avatar
merrick
Other than the 4 rocker points, 1)behind the front wheel and inward about a foot 2) forward of the rear wheel and inward about a foot. Jack only on the frame(painted black). You will need some scrap wood on your floor jack to keep from crushing stuff. You can also get a floor jack adapter to lift under the diff.
Old Jan 29, 2004 | 09:29 AM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Re: Jack it up! (merrick)
... You can also get a floor jack adapter to lift under the diff.
here it is:
http://www.corvettegadgetman.com/products3.html
Old Jan 29, 2004 | 12:24 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Jack it up! (tobijohn)
here it is:
great piece for rear jacking... :iagree:
Old Jan 29, 2004 | 12:29 PM
96CollectorLT4's Avatar
96CollectorLT4
forget about jacking........ www.kwiklift.com
:cheers:
Old Jan 29, 2004 | 07:21 PM
sraft's Avatar
sraft
Default Re: Jack it up! (96CollectorLT4)
You can jack along the outer, bottom edge of the frame - the points are identified right on the rocker covers (they are on my '94). As for the jackstand locations.....just see my sig pic.
Old Jan 29, 2004 | 07:31 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Isn't that jack adapted tool just a piece of I-beam?
Old Jan 29, 2004 | 07:39 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
For the front, first drive up on some 2 x 6's, then you can place regular ramps or a floor jack and lift. Place jack stands where the swarbar connects to the frame.
For the rear, I use the jack-a-vette, then you can see where I placed the jackstands, I've also placed them forward of teh rear wheels on the frame, it all depends on what needs work.
Old Jan 29, 2004 | 08:12 PM
eschoendorff
St. Jude Donor '08
Default Re: Jack it up! (Mr Mojo)
Great pix! They help!
Old Jan 30, 2004 | 12:20 AM
MrWiggly's Avatar
MrWiggly
Mojo - Thanks for the info, that's great!
To Jack it up!
