I tried for help in tech with no reponse :smash:
Anyone know how many ohms resistance I should see on my cold start injector ??
I'm putting in new injectors and don't want to have to tear into it again.
Dan :cheers:
Ohms will only tell you part of the story with the injector. It could leak but have normal ohms. Pressurize the fuel rail with the cold start injector out of the intake and plug disconnected to see if it leaks.
Yes, but I also want to check the coil.
Do you have an idea?
I measured 16 ohms on the injectors and only 4 on the cold start injector,
I would like to know if 4 is normal for the cold start injector.
:cheers:
