Camber Brace
:cheers:
What does a "camber brace" and "cross bar" do?
I'm familiar with "tower braces" which run from either the firewall to a shock or strut tower, or from tower to tower. They can't be the same thing cause there are two of them, and they have different names
Would anyone be willing to shed some light for me?
Thanks.
Glen
Sort of.
When I get a minute (see sig), I will saw my camber brace in half, drop the two ends down a couple of inches and bolt them to the frame crossmember. I reckon it will be a more rigid job triangulated to the frame than tied to each other.
Incidentally, an old trolley jack is not mandatory to make your own, I just used what I had. Thats why I never throw stuff away! :D
:eek: :eek: :eek: :eek: :eek: :eek: :eek:
I'll keep my R-D Racing Camber Brace, thank you. I like driving my car without the fear of it cracking (see pic) and shoving a chunk of metal through my hood!!
Doesn't look to strong to me. Any flex at all and it serves no purpose.
Thanks.
Glen
Cross Bar: Ties the upper seat belt points to the cargo area (Under the mounts to store the top.). Makes the rear of the car a little more ridged, similar to what the Camber Brace does to the front.
Cross Frame: X shaped brace similar in design to the braces put on the convertible C4's. The coupes did not get this. Strenghtens the frame and helps reduce the flexibility of the C4 coupe without the targa top on.
Hope this helps you understand what each one does. Took me a while as well. :cheers:
Mike
If you triangulate from where your mount attaches now down to the factory cross member by cutting your brace, you will be adding bending loads to the cross member. It would be stiffer overall if you ran a new diagional from one end of your existing brace to the cross member.
One of these days I plan to do that to my R-D brace one of these day. I will leave the attachment just snugged so I can see how much things are moving now from the paint scratches before I tighten it.
Dick
[Modified by xs650, 11:25 AM 2/5/2004]
My hat is off to Dave for the job he did on making the brace fit so that it is a straight forward bolt in operation.
That is a crowded area in front of an LT1/LT4 engine and designing and building it so it can be installed by following some simple instructions without taking the rest of the car apart took a lot of talent.
I seriously doubt that if you had detailed drawings of the R-D brace and took them to a fab shop, you coukd get small quantities of them built for less than Dave is selling them. Daves price is very reasonable and people like him should have our support so they will keep cranking out goodies we want .
If you can design and build your own, that's even better. But, not many can do that, and most of those of us who can won't because we recognize what a job it is.
When I first got the brace, I saw several ways to improve the design:) When I installed the brace I then understood why some things weren't done the way that looked good when the brace is sitting on the table. After I installed it, I just stood back and admired the design. It was designed by a master.
[Modified by xs650, 1:50 PM 2/5/2004]
Thanks for the input and compliments.
Others who shall be nameless. That is NOT a crack. It is scruffy welding. The pic was taken during test fit stage, when it was sprayed with silver aerosol paint. It is now powdercoated and has done 6000 miles on the car without issue. Thanks for your concern however. :)
R&D makes a standup, grade A quality pc.
I'm sure it is, but come on, $200. :crazy: I think some one on this board could make one just as good for a lot less. To me it's just another example of a vender putting it too Corvette owners. :cheers:
In case you don't read everything on this Forum, it only cost members here $160.00. My distributors such as Vette Brakes, Mid-America, and Ecklers all sell the "Camber-brace" for $199.95 per agreements with my company to offset their cost of advertising and make a small profit to stay in business.
I invite you to design and develop your own version. There is a lot more involved than what you can see in a picture. I'll guarantee you that our's will be cheaper in the long run.
Feel free to call me anytime if you have any questions.
Dave
Easy. I haven't install one on mine yet but I was there when Whitvette installed his and being minimally competent myself, I wouldn't be afraid to try it. The right tools and an extra pair of hands would definitely help. I don't recall the exact tools necessary but they weren't anything that a reasonably stocked toolbox wouldn't already have. Whitvette could tell you for sure...
1. Slotted screwdriver, loosen the clamps holding the rubber air duct and remove.
2. I think it was a 19mm sdeep socket that I used to remove the front upper control arm bolts on both sides. To gain more room to access this, pull the fender well weatherstriping off and with a 10mm socket, remove the center portion of the inner wheel well. (I think there are 6 small bolts)
3. Lower bar into place with plastic covering in place. Watch the coolant temp sensor. If you let it drop into place, you can break the sensor. A lot of guys warned me about it, so we took special care.
4. Put the front bolts back in with the shims that you removed. If the bolt is not long enough, use one of the longer bolts that come with the bar as a replacement. (I had to do this on the driver side, passenger side just required the factory one.)
5. Torque them to specs. Don't remember what the specs are, had my service manual while doing the work.
6. Install rubber air duct, tighten clamps.
7. Get in car and hit the corners hard. You will have a :D from ear to ear! Enjoy!!
BTW, This is pretty much the directions to do it. Dave also has some nice pictures and tips on how to get the bar into place. This is one of the top mods you can add to your Vette and get immediate results!! John, when are you getting yours? :D
:cheers:
Neil
I waiting for you to buy that C6 so I can get yours used.... ;)
And to think John, all I got from you was an envelope full of beach sand , and a couple of leaves :lol:
Seriously though, this reminds me to contact Dave, like I've been SAYING I'm going to do for a year now... I guess at $160 I'm kind of glad I procrastinated :yesnod:
Keep dreaming! :jester :D No way I am going to part with my C4! Besides, then I would have to get a new email address. :lolg:
