Oil Temp ?
Old Feb 14, 2004 | 02:32 PM
lbitp37's Avatar
lbitp37
Default Oil Temp ?
Temperature here is in the 20's 30's.
Is it normal for the oil temp. to go up much slower than the water temp ??
Old Feb 14, 2004 | 02:57 PM
Wayne88's Avatar
Wayne88
Default Re: Oil Temp ? (lbitp37)
Mine goes up slowly in cold weather.
Don't know if its normal or not.
I'll stay tuned for the answers.
:cheers:
Old Feb 14, 2004 | 03:08 PM
HG's Avatar
HG
Default Re: Oil Temp ? (Wayne88)
My 88 does in both summer and winter. THe water temp far outpaces the oil for the first 5 or 10 minutes of driving. Then, the oil temp usually goes slightly higher than the water. Summer temp of the oil is usually over 225 F
Old Feb 14, 2004 | 03:26 PM
JSA 007's Avatar
JSA 007
St. Jude Contributor
Default Re: Oil Temp ? (HG)
The oil temp ALWAYS goes up slower than the water :yesnod: Many people think, oh the water's up to temp so I'll floor it now... :nono: You gotta watch the oil temp too. It's slower...
:cheers:
Old Feb 15, 2004 | 09:17 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
:iagree:
Yep. Every car I've owned with oil temp readout does the same thing: oil temp lags, then surpasses coolant temp. It's normal.
Larry
code5coupe
:seeya
Old Feb 15, 2004 | 09:42 AM
Bilyk's Avatar
Bilyk
Default Re: Oil Temp ? (rocco16)
mine never goes higher than the coolant temp... actually it's weird because my vette runs ALOT colder than any other L98 i have seen
Old Feb 15, 2004 | 09:52 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Oil Temp ? (JSA 007)
:cheers:
:withstupid: :lol:
my oil temp takes 15+ to reach water temp,, then run constant at about 225... normal... :thumbs:
Old Feb 15, 2004 | 10:16 AM
vetterlatethannever's Avatar
vetterlatethannever
Default Re: Oil Temp ? (vinnies87)
Yep, it's slower alright, mine even starts out colder!! If it's 40 outside when I get in my car my water will be 45 and oil will be 36 or something like that.
What should oil temp. be before "getting on it"? I wait til after 150, never before it!!
Old Feb 15, 2004 | 08:22 PM
Pete K's Avatar
Pete K
Default Re: Oil Temp ? (vetterlatethannever)
My friend has an engine dyno and even in the shop the oil temp takes time to rise. not sure why this is but no pulls until minimum 180 degrees f oil temp
Old Feb 15, 2004 | 08:27 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Yep, it takes longer!
At cruising, my water temp is around 177 and oil at 196
Let it idle for a while in the driveway before driving it. Not a good idea to really get into it until oil is somewhere above 150
:seeya
:steering:
[Modified by jackdaroofer, 8:29 PM 2/15/2004]
To Oil Temp ?
