Will digital Ohm meter really work?
Old Mar 16, 2004 | 09:58 AM
rick lambert's Avatar
rick lambert
Default Will digital Ohm meter really work?
Haven't needed to read codes yet-I was talking with a friend about paper clip for reading codes, when he said the digital Ohm meter will actually show the numerical such as 32 on the meter, anyone try this? :rolleyes:
Old Mar 16, 2004 | 10:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Will digital Ohm meter really work? (rick lambert)
Never heard of that one :confused:
Old Mar 16, 2004 | 11:33 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Ummm... no. That doesn't make any sense at all. Where would you place the leads for the Ohm meter, in the same place as the paper clip would go? If so, that line is simply a diagnostic mode selector on the ECM. It only changes the mode in which the computer is operating.
There is a method of displaying the actual codes on the digital dash and being able to cycle through them with the fuel and trip buttons but it still requires the paper clip trick.
Old Mar 16, 2004 | 01:50 PM
JasonL's Avatar
JasonL
Default Re: Will digital Ohm meter really work? (ShawnZR-1)
I bet your friend saw somebody using a handheld code reader and mistook it for a DVM.
Old Mar 16, 2004 | 02:36 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default Re: Will digital Ohm meter really work? (JasonL)
:iagree: Cant do it with any standard hand held dmm.
Old Mar 16, 2004 | 03:06 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Default Re: Will digital Ohm meter really work? (longhorn_C4)
:withstupid: :D
Old Mar 16, 2004 | 10:14 PM
TRWSD90's Avatar
TRWSD90
If you hook up your red lead to the signal side of the terminal when in resistance. You may even cause a problem in the cor or meter.
Old Mar 16, 2004 | 11:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Though a DMM is a valuable tool...do NOT measure resistance at the ALDL while connected to the ECM.
You need either a scan tool or a paper clip to pull codes.
Old Mar 17, 2004 | 04:08 AM
86PACER's Avatar
86PACER
:skep: :skep:
To Will digital Ohm meter really work?
