Another WEATHERSTRIP thread
Old Mar 31, 2004 | 12:21 AM
dtorc4's Avatar
dtorc4
Default Another WEATHERSTRIP thread
I've been searching the archives for about an hour now. I've come up with some good info, but I have a couple more questions.
I'll be replacing the roof front weatherstrip in the next couple of days. While searching, I found one thread that said that this piece does NOT use any adhesive. It says to unscrew the metal strips at each end of the top, clean them, then reinstall with silicone sealant underneath. Is this true?
Also, what exactly have you used to remove the old W/S boogers? I don't have any specialized tools, I was thinking of just using a small slotted screwdriver and some 3M adhesive remover. Any other thoughts?
Any more tips/ideas/suggestions are welcome. Moans, gripes, and complaints will receive a :beatdeadhorse: . :D
Thanks guys.
[Modified by dtorc4, 11:21 PM 3/30/2004]
Old Mar 31, 2004 | 11:55 AM
dtorc4's Avatar
dtorc4
Default Re: Another WEATHERSTRIP thread (dtorc4)
Going ^^^
Old Mar 31, 2004 | 11:58 AM
Rocky Rothrock's Avatar
Rocky Rothrock
:lurk:
Old Apr 1, 2004 | 07:26 AM
Richard G's Avatar
Richard G
Going to tell you how I installed my weatherstrip and what happened to me. Removed old and scraped off leftovers.
Fit top part into grove and glued sides. Took putty knife and held back top piece and glued it to front of winshield frame.
Let all of it set for 24 hours and installed top. Two months latter I pulled car cover off and top was cracked. Repaired top and put in rain yesterday, no leaks.
I am guessing that cold weather and a new thicker than old weatherstrip caused the crack. Next time I will do it in warm weather. :yesnod:
Old Apr 1, 2004 | 07:05 PM
dtorc4's Avatar
dtorc4
Comeon y'all, I know there are more of you out there who have installed this piece. Let me know what you saw and did!
If you don't respond to this thread, my car is going to catch on fire! :D
[Modified by dtorc4, 7:34 PM 4/1/2004]
Old Apr 1, 2004 | 08:33 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Are you talking about the weatherstrip that goes over the windshield and along its side? :confused:
dtorc4's Avatar
dtorc4
Default Re: Another WEATHERSTRIP thread (Dudeurgettnavette)
:yesnod:
[Modified by dtorc4, 7:33 PM 4/1/2004]
Old Apr 2, 2004 | 12:15 PM
dtorc4's Avatar
dtorc4
I'm not letting this one go down that easily. I want to make sure I do it right the first time.
Old Apr 2, 2004 | 12:25 PM
Moxxi's Avatar
Moxxi
I would be interested in the answer, too. I will need to replace my soon.
Teh Nam's Avatar
Teh Nam
try here:
http://www.corvette-rubber.com/installation.html
Old Apr 2, 2004 | 12:43 PM
Dudeurgettnavette
Thanks guys.
I had adhesive on mine. I bought this to help me take the weatherstrip off http://www.ecklers.com/product.asp?p...QTBPVPCKES0C91. I didnt use much if and adhesive remover. When I started on one end I was able to get the adhesive to come off with the weatherstrip, then all I had to do was peal the weatherstrip off the retainer. I think I was lucky though.
Old Apr 3, 2004 | 12:33 PM
Glasman66's Avatar
Glasman66
Ripped it out, cleaned it off and glued it down with windsheild urethane :D off course. No leaks no problems.
The key I think was to get the top back in the car and put the windows up to let it sit.
Of course now we move to our next leak :sad: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse: :beatdeadhorse:
To Another WEATHERSTRIP thread
