Optima Batterys, Side Terminals Only?
Old Apr 6, 2004 | 09:18 PM
LT4play's Avatar
LT4play
Default Optima Batterys, Side Terminals Only?
I looked through some of the other threads, and couldn't find anything definitive. Does Optima make a battery with side terminals only? My parts store said No.
The top positive terminal is leaning slightly against the part that sits above the battery (not a tight fit, but definately touching). Is the cap that covers the top terminal going to protect it over the life of the battery?
Old Apr 6, 2004 | 09:27 PM
96KICKS's Avatar
96KICKS
CI 7-8 Veteran
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Optima Batterys, Side Terminals Only? (Sting1978)
I could not get one with only side mounts. Parts store said no to me also.
That's exactly how mine fits.
I hope the cap protects it, so far I've had no problems, although the battery has just been put in within the last month. It does have nice starting power!
Old Apr 6, 2004 | 09:32 PM
LT4play's Avatar
LT4play
Default Re: Optima Batterys, Side Terminals Only? (96KICKS)
I pulled it out and can already see a little red plastic on that metal piece, plus a slight indent into the cap. I really like the Optima battery, but am a little bit uncomfortable with this. Maybe I am just a spaz. :confused:
[Modified by Sting1978, 8:33 PM 4/6/2004]
Old Apr 6, 2004 | 09:59 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
Just cut off the top post, that's what me and most everyone at the track has done. Should take all of about 10 seconds with a hacksaw. Then cover the cut area so nothing can ground out on it, I used some silicone.
Old Apr 6, 2004 | 10:03 PM
96KICKS's Avatar
96KICKS
CI 7-8 Veteran
Default Re: Optima Batterys, Side Terminals Only? (Mr Mojo)
It's so nice to have you around here ;)
Old Apr 7, 2004 | 12:30 PM
wake's Avatar
wake
The only problem is you lose the warranty on it if you do that... On my last Vette, I just notched the cruise control bracket where the POS post is when installed... Worked great... :thumbs:
To Optima Batterys, Side Terminals Only?
