Backup light switch
Old Apr 17, 2004 | 12:22 PM
CanadaVette's Avatar
CanadaVette
Default Backup light switch
Anybody ever try removal of the backup light switch on the 6-speed tranmission by accessing it from above through the shifter boot area? I have to replace one on my 94 and was wondering if anyone had tried that. Accessing from below appears to be the typical way, but the space is very tight. Just thought I'd ask before I spent the time removing the console, boot, etc.
Old Apr 17, 2004 | 03:37 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Backup light switch (CanadaVette)
I was looking through the archives and found very little info. Maybe this bump will help us both. :cheers:
Probably would have better luck if Mojo moved this over to Tech for us. :)
[Modified by Rob 91Z07, 2:41 PM 4/17/2004]
Old Apr 18, 2004 | 10:50 AM
CanadaVette
Default Re: Backup light switch (Rob 91Z07)
I'm in Tech already. Check it out.
To Backup light switch
