Climate Control Vac. Lines
Old Apr 17, 2004 | 11:56 PM
TempleCorvette's Avatar
TempleCorvette
Default Climate Control Vac. Lines
Does any know where the main vacuum is connected within a 1984? Normally when you switch to defroster, Max Air, etc. the control changes where vacuum goes and opens/closes flaps. However mine is blowing air from all possible outlets regardless of what is selected. The Haynes manual doesn't even go into this section of the car. I've traced the lines (which are hooked up to the control head) and two lines (inside car) run to the condensor box and must run out to the engine somewhere (just don't know where). Any ideas will be greatly appreciated.
Cheers from Temple Texas
Old Apr 18, 2004 | 12:02 AM
Wayne88's Avatar
Wayne88
Default Re: Climate Control Vac. Lines (TempleCorvette)
Don't know. but you might try C4 Tech/Performance forum.
That's where the brains are. :thumbs:
