From: 89 Coupe L98 Auto 54k Dk Red Med Oak Forest, Illinois
Oil Change
New Guys on the Block. Just bought a 89 coupe L98 Dark Red Metellic.
My Son talked me into going Half's.
Car has a engine oil cooler. Does this increase the Oil capacity??
Manual says 5 quarts, but nothing about oil cooler.
Have learned alot on the Forum. Keep up the good works. THANKS
Ok...maybe yours is routed different than mine, but lets think about this.....Adding a cooler that wasn't there before is obviously adding capacity to the oil system, so you should add a bit to cover that additional space just to be safe anyway.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Re: Oil Change (Sam Lam)
Please describe how the oil cooler looks and where is it located? My 89 has engine coolant going to the oil filter area.....is this the cooler?
Sounds like it. While my Corvette does not have an oil cooler, my VW Scirocco does....and it is an 'adapter-like' device installed between the oil filter and the block. It has coolant lines running to it and its purpose is to stabilize oil temps (rapidly warm the oil at startup and prevent excessively high oil temps during running).
