I don't know, that's an all original numbers matching spare. It even has the original paint, rust, and dirt on the wheel. It might really help the car show 100%
When I dropped the spare out of my 86 it hadn't seen the light of day since it was put in at the factory. I chucked the spare and added a can of Fix-A-Flat to my inventory.
Was there any air in it?? When I pulled the spare on my 87, not only was it flat, but the tire had pulled off the wheel bead and the corrosion was so bad, I had to have the tire removed and I had to grind down the bead area to get it to re-seat!
I now have one of those spare tire air hoses from Griot's garage on both Vettes. I can check the air pressure without having to drop the spare: http://www.griotsgarage.com/catalog....2530&SKU=44407
Worth the 10 bucks!!
Mine realy cleaned up nicely too. In fact as I type I can look across the office and see that it's still very shiny (I use it as part of an end table... ).
A puncture repair kit and a pair of dykes along with a cell and plastic is all I carry these days.
It was actually really close to the correct pressure. That Griot's Garage thing looks pretty slick though. I should pick one of those up when my money tree blossoms in another few months here
From: No more yankee my wankee, the Donger is tired!
Re: Nice clean spare tire! (yellowlust)
The spare won't fit over my brembos front or rear. So it's just added weight.
hahahaha looks like mine when i took it out .when i seen how small it was i said put it back im not putting that thing on my car .can u picture what that little thing would look like on with those big tires .if i was beside the road with a flat i would of put it on but luckey i was in my yard.and had a big spare tire in the shed.yea it was so dusty u wouldnt think it would get so dirty under there
[QUOTE]Was there any air in it?? When I pulled the spare on my 87, not only was it flat, but the tire had pulled off the wheel bead and the corrosion was so bad, I had to have the tire removed and I had to grind down the bead area to get it to re-seat![QUOTE]
Mine was also flat and wouldn't hold air. It doesn't matter too much to me, though...If I were to ever get a flat, i'd probably just call for a flat-bed or something to carry it to the nearest Chevy dealer. I doubt I'd try to drive on that space saver.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Re: Nice clean spare tire! (redhotandrollin)
I know what you mean.
On a run last year, a Z06 got a flat rear tire. He had no spare, so I loaned him mine. You don't think that looked hilarious??!!
