Window Adjustment
Old Jul 8, 2004 | 02:43 PM
dstuhr's Avatar
dstuhr
Default Window Adjustment
I have a small gap above my passenger window. Is there a way to adjust how far the window rolls up? Thanks in advance.
Old Jul 9, 2004 | 09:46 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Haven't had to yet, but there are stops on the regulator and adjustments for glass. Shoot me your email and I'll send the info from my 86 manual.
Old Jul 9, 2004 | 10:34 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
I just changed both of my windows and there should be three bolts that can give ou approx. 1/2" adjustment up or down/or side to side. YOu should be able to do it by removing only the door panel. You will have to roll the window up or down to get access to the bolts through the aluminum panel. Good Luck
Old Jul 9, 2004 | 07:10 PM
Steel Blue 91's Avatar
Steel Blue 91
Here's a link to the tech tip:
https://www.corvetteforum.com/techti...=206&TopicID=2
Old Jul 10, 2004 | 02:55 AM
dstuhr's Avatar
dstuhr
Originally Posted by Steel Blue 91
Thanks for the help, that did the trick. Too bad I wasn't bright enough to find that on my own.
To Window Adjustment
