New plug wires...recommendations?
Old Jul 9, 2004 | 01:50 PM
95vetteman's Avatar
95vetteman
Default New plug wires...recommendations?
I need to replace the plug wires on my 95 coupe. Should I just go with the GM ones? Anybody have a really good experience with some other kind?
Thanks.
Old Jul 9, 2004 | 02:05 PM
Wayne88's Avatar
Wayne88
I just tuned-up mine.
I used AC Delco wires, dist. cap & rotor.
Bosch platinum plugs
But, I don't think a differnt brand makes much difference in performance
with a stock engine, like mine.
Other members may disagree.
Old Jul 9, 2004 | 02:46 PM
myblue91's Avatar
myblue91
I used all ac delco when I did my tune-up. My 91 is also stock, had bosch plugs in prior and don't notice a difference in the plugs
Old Jul 9, 2004 | 03:02 PM
LT1Vetteguy78's Avatar
LT1Vetteguy78
i see alot of people here use Taylor Wires, i personnally have Moroso Blue Max
Old Jul 9, 2004 | 03:55 PM
linkschamp's Avatar
linkschamp
When we had the '92 tuned at a GM dealership (plugs, wires, coil, icm, waterpump & opti spark) we stayed entirely GM (except for the Bosch Plat-4's) - just trying to keep 100% electrical compatiblity as designed.
We just put a Delteq Opti-Direct system in using Moroso Blue Max Spiral Core wires!
Old Jul 9, 2004 | 04:07 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Taylor here. Use them on the Vette. Use them on the Chevelle race car. They are a really good wire!
-Rick
Old Jul 9, 2004 | 04:17 PM
FlyboyZR1's Avatar
FlyboyZR1
MSD 8.5mm wires are the only ones I would consider.
Old Jul 9, 2004 | 05:03 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
I'm having great success with my Accel Performance silicone plus, Graphite, RFI Suppression core 8.8's Plus, I think the yellow with red boots looks tight.
Old Jul 10, 2004 | 03:15 AM
mitymek's Avatar
mitymek
im confused.
you had a dealer put in a new opti and wires and then added the opti-direct?
those are spendy i see (670 bucks),any noticeable affects from it?
Old Jul 10, 2004 | 06:32 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Same here...and i love'm!
Old Jul 10, 2004 | 07:21 AM
STL94LT1's Avatar
STL94LT1
Default Taylor Spiro Pro
Get the Taylor spiro Pro 8 mm wires, you won't be disappointed.
Old Jul 10, 2004 | 08:13 AM
C10 JDR's Avatar
C10 JDR
I got a 30' length from Summitt, along with new boots, this way I could cut them to length to route them under the headers. I have bought made up sets before and never been happy with the individual lengths.
The Taylors come in fancy colours too. I thought I would be daring and chose black.
Old Jul 10, 2004 | 10:16 AM
Kale's Avatar
Kale
I agree.
I had the yellow accel wires before, and they were ruined within.... 10,000 miles. So far the MSD's have been running perfectly the last 15 or so.
Old Jul 10, 2004 | 11:41 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
same ones here... Blue to go with my engine scheme
Old Jul 10, 2004 | 07:32 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Default Plug wires
I use the Taylor spiro Pro 8 mm wires, they fit & look just fine.
Old Jul 11, 2004 | 01:27 AM
linkschamp's Avatar
linkschamp
Originally Posted by mitymek
im confused.
We had the dealer put in the new "stuff" (all GM) and after only 28K miles, the Opti crapped out... this time, we opted for the Delteq - and glad we did!
I have a complete report on the Delteq install and results ready for publication on the forum, but can't figure out how to post it under Tech-tips... its 19 pages with pics!
Old Jul 11, 2004 | 02:11 AM
bogus's Avatar
bogus
I love the Taylors, too... mine are green.
To New plug wires...recommendations?
Old Jul 11, 2004 | 02:39 AM
skateparkdave
linkschamp, Ive recently submitted a tech tip and although it hasn't been put up yet, here's how,
At the top toolbar of this page click the "OTHER" tab then C4 then when C4 tech tips opens you'll see another C4 tech tips tab at top area of that page. Click it then you'll see another tab that say's "Submit tech tip" Click here and follow the simple instruction. I'm not sure how much you can submit. 19 pages may not fit. You may need to cut it down to just the meat and potatoes. And like I said, it takes a while for them to get them posted after submission. It's been like 2 weeks since I submitted mine. So be patient. They have their hands full,I'm sure, with all the new software adjustments and what-not,
Good luck,
Dave
Old Jul 11, 2004 | 03:46 AM
mitymek's Avatar
mitymek
nice!! lookin forward to it.thanks for thinkin of us here and taking the time to document it!
i want to get mine to where it fires instantly when i hit the switch.
Old Jul 11, 2004 | 12:05 PM
tjwong's Avatar
tjwong
The GM wires will fit and perform just fine. If you want some fancier wires you can option for the 96 LT4 wires if you want red wires. Taylors are fine aftermarket wires and with minimal effort they can be made to fit the stock wire hangers and looms. Going to a wire any larger than an 8mm wire will make your weekend of plug wire installation miserable. Trying to feed them into and making the larger wires fit a loom made for a 7mm wire will reall PI** you off.
I see no benefit whatsoever from going to a larger wire in a stock or even a modified street driven car. I know I may get flammed for that statement but I can tell you from being an electrical engineer that as long as the insulation is not compromised on the wire and if the insulation as designed is adequate for the voltage level there is no need for a larger OD wire with additional insulation qualities. As for the low resistance wires. The only benefit would be from additional heat protection. I can also tell you that for the given length of wires and for the higher resistance wires, there would be no appreciable voltage drop between a wire that is 2 feet long and a wire that is three feet long. One has to know that with an HEI or most any late model ignition system there is a 50kV voltage potential there. A typical spark plug takes only 15kV to jump the gap, those requirements go up to as much as 25kV under high RPM and higher compression situations. If you want aftermaret wires the Taylors are the way to go. Plus they have several colors to choose from
