Sick '93
Old Jul 10, 2004 | 08:47 AM
Fundo's Avatar
Fundo
Default Sick '93
Earlier this week replaced water pump, top/bottom rad hose, thermostat, plugs and had injectors cleaned on my '93 LT-1.Opti-Spark OK. Then yesterday after getting gas troubles began. Car began to run horribly--stalling, hesitating, backfiring, pinging etc. Also started to run hot up to 235 degrees. No check engine light came on. What can be the cause---clogged fuel filter, bad O2 sensor, bad MAF sensor, faulty ECM, air in the cooling system? What do I need to check? Afraid it will not make it back to the dealer without craping out. Owning a 'Vette can be frustrating at times.
Old Jul 10, 2004 | 09:57 AM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
You say your opti is ok. Changing the water pump would lead me to check that again. You may have gotten it wet. Good luck
Old Jul 10, 2004 | 03:11 PM
rubyred93's Avatar
rubyred93
Typically when changing out a water pump it is usually a wise idea to also change the Opti-Spark at the same time. Is the Opti relatively new and that is why you did not change it out also?
Opti's hate water, and there's a chance it could have gotten wet.
Old Jul 10, 2004 | 03:15 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Any possibility that you got bad gas?
Old Jul 10, 2004 | 03:47 PM
bogus's Avatar
bogus
1993s don't have a MAF, they are MAP or Speed Density motors...
Your describing a wet opti. Why did you replace the waterpump?
Are you sure the injectors are ok? Just cause they were cleaned doesn't mean the shop messed them up in the process...
Also, check fuel pressure.
Old Jul 10, 2004 | 09:28 PM
Fundo's Avatar
Fundo
Default Sick '93
Problem was condensation in fuel sytem which was solved by adding a bottle of dry gas. Car is not driven very often and I found out from a Service Tech at a local repair shop that when putting gas in a car that sits for long periods there is a risk of this moisture problem surfacing, gas and water don't mix well. Good practice would be to add a bottle of dry gas every time you fill up. Lesson learned.
Old Jul 10, 2004 | 10:20 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Glad to hear it turned out to be nothing more!
Old Jul 11, 2004 | 08:30 PM
red-y's Avatar
red-y
Glad it was not your Opti -
To Sick '93
