Procharger Engine Pics
Old Jul 11, 2004 | 12:53 PM
LT1Vetteguy78's Avatar
LT1Vetteguy78
Default Procharger Engine Pics
Just a couple pics of the Procharger setup....The Two lil K & N filters look cewl, but i am not sure of there function?
See here
Old Jul 11, 2004 | 02:20 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Sweet! Hows it run?
Old Jul 11, 2004 | 02:39 PM
LT1Vetteguy78
It runs fine...pulls hard...its just noisey at idle and goes away while drving. i actually was reading up on the noise and i found an article from Gate Rubber Co...they make the Micro-v Belt running on the procharger....i found help here....
Belt Noise Troubleshooting
I am thinking this is the problem, i think its definitly #7 on that page cause thats exactly what happens
Old Jul 11, 2004 | 03:19 PM
JF_AH_64's Avatar
JF_AH_64
Looks good! I am jealous.
Old Jul 11, 2004 | 05:12 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Sweet!
Old Jul 11, 2004 | 05:57 PM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
cool!
Old Jul 11, 2004 | 06:09 PM
Cozmo's Avatar
Cozmo
Many questions, as I have been thinking about doing this.
Did ya buy it new or used?
If used, what source and how did you know all of the parts were there?
If new, where and how hard was it to get the right kit?
Were you able to install it yourself or did you need professional help?
Old Jul 11, 2004 | 06:29 PM
BowTieBlood's Avatar
BowTieBlood
Old Jul 11, 2004 | 06:51 PM
LT1Vetteguy78
Longhorn,
I got everything done through J & M Motorsports in manchester ct....They purchased it for me..and installed it...here it a break down as i have posted before for the cost.....The numbers in my sig represent just the install with no computer reprogramming, + i am adding 42lbs injectors as soon as they come in...hopefully will have the new numbers at teh end of this week from the dyno
Procharger Pcs1 $4419.04 +$60 shipping
Installation 15 hours(really took them 34 hours, but they didn't nail me for them) $1200 dollars..
Dyno Time 3.75 hours $300 dollars
Boost Gauage $59.95 Pod $29.95 Install $120
Hazardous Material $7.50
Freon $12.88
Accumulator $83.84
Tranny Fluid $2.25
3" 90 degree Elbow(shrug) $35.86
Spark plugs $23.84
3/4 hose connectors(shrug) $5.16
Over FLow tank(stock one was way to big) $13.92
K & N Vent Filters $53.30
Shop Supplies $7.50
O, Lets not forget our Lovely sales tax of $386.10
Total $6821.09
Old Jul 11, 2004 | 07:08 PM
Cozmo's Avatar
Cozmo
Thanks for the info!
Old Jul 11, 2004 | 10:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Jul 11, 2004 | 10:36 PM
LT1Vetteguy78
Anyone know what those Two K & N Filters coming out the the covers are doing, i mean whats their function?
Old Jul 11, 2004 | 11:20 PM
Jim Sitton's Avatar
Jim Sitton
The filters are for crankcase ventilation. You can't run the normal PCV system on a boosted motor.
Old Jul 12, 2004 | 12:28 AM
zelement's Avatar
zelement
What kind of tires are you running up there? Looks like some H rated touring tire.
Old Jul 12, 2004 | 06:34 AM
LT1Vetteguy78
they are 255/40/ZR17's Bf Goodrich g-force t/a KDW and Comp T/A 285/40/zr17s in the back
Mistake they are KDW, not KDWS
Old Jul 13, 2004 | 04:28 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Great set-up.
Old Jul 13, 2004 | 04:38 PM
vvv90's Avatar
vvv90
Yes, they are for crankcase ventilation since they removed your PCV.
I should let you know that the way they did it was THE RIGHT WAY not the ATI way.
In the ATI installation manual it says to tie those two hoses (the ones with the filters) together with a T fitting and run it to the intake filter in your passenger wheel well. NOT GOOD as it will coat the blower and intercooler with oil over time. Plus the T'ing of the two 3/4" hoses into 1 causes a restriction.
I'm glad the installers knew this was a bad idea.
Now upgrade your fuel pump before your AUX that they installed fails and leans out your motor. This is something you can do, it's a snap
www.racetronix.com
This and those 42lb injectors will give you a "more appropriate" fuel system
To Procharger Engine Pics
Old Jul 13, 2004 | 04:42 PM
vvv90's Avatar
vvv90
That "shaking-a-tin-can-full-of-rocks" sound is normal at idle. It's the straight cut gears of the step up. It will go away a little down the road.
BTW: At 500 miles you have to change the oil. Then every 3000 miles after that. Did the shop give you the bottles of oil that came with the kit?
changing the oil is a pain, as the whole head unit needs to be taken out.
Old Jul 13, 2004 | 05:16 PM
LT1Vetteguy78
Yeap i got the oil....Yeh i heard about the oil change should be fun To bad you didn't live closer VVV :P
Old Jul 14, 2004 | 10:27 AM
vvv90's Avatar
vvv90
Welp, you always got us at the forum to help you through it
It's not hard, just time consuming.
steps in order:
1.) remove 3" outlet hose from blower (one hose clamp)
2.) Loosen hose clamp on plastic inlet "hat" intake
3.) Remove belt only off of alternator
4.) Remove bolts holding blower to bracket
Walla!
