LT4 specific pistions
Old Jul 17, 2004 | 02:53 PM
ericcer's Avatar
ericcer
Default LT4 specific pistions
I never read about specific LT4 pistons other than LT4 had more compression than LT1s which I thought was head design. I am getting my LT4 rebuilt and my mechanic noticed that the pistons were quite a bit lighter than the other LT1's he was rebuilding. In fact, there is LT4 stamped on the pistons in more than one place.
I guess they stamped all the LT4 parts. I will have to see if the crank has LT4 stamped on it too.
Old Jul 17, 2004 | 03:24 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
LT-1 piston P/N: 10159437
LT-4 piston P/N: 12551526
Larry
code5coupe
Old Jul 17, 2004 | 06:40 PM
VenkmanP's Avatar
VenkmanP
If neither you or your mechanic is aware of the differences between LT1 and LT4 you need to do a little research before continuing.
Old Jul 17, 2004 | 11:04 PM
DieL's Avatar
DieL
the LT4 pistons have shallower valve depressions which raised the cpmpression and used different rings than the LT1. im assuming your'e going to use speedpros or something anyways so it dont matter.
Old Jul 19, 2004 | 04:36 PM
ericcer's Avatar
ericcer
Why don't you take one of these clown!
To LT4 specific pistions
