Just a fun VID
Old Aug 4, 2004 | 01:12 PM
hngacurv's Avatar
hngacurv
Old Aug 4, 2004 | 04:02 PM
JSA 007's Avatar
JSA 007
St. Jude Contributor
Originally Posted by 93JetJocky
Yep very familiar with density altitude having flown out west for a dozen years or so. I was wondering just how well the computer compensated to lean the engine for those aspects and if you noticed the loss of HP. That's good to hear the cooling system still works fairly well in the less dense air, I was watching the Pike Peak race just recently on TV and those guys were complaining about how their engines were running hotter in the higher altitudes. I figured with the Vette's engine so closely cowled it might be a little more of problem out there. I sure would luv to take my Vette out to Albq (daughter lives there). It would make for some awesome pictures to get with the car and the scenary.
Kewl thanks for the reply.
Yeah the cooling's fine now, but keep in mind that's with a 160stat and a Thermomaster chip. Even then, it can still heat up real fast in this heat It doesn't stay below 180* for long in the summer And in a traffic jam in the middle of the day it got up to 200 But this is still much better than stock It used to get up to 230 in no time, when the fans kicked in, just how it gets up to 180 now...and in the extremes when it hit 200 now, it would get close to 250 before
And I don't know if that chip compensates for the higher altitude ...but I did by cranking the distributor a little Also I can't really say if I notice the 10% less hp due to the DA because I have never run this car at sea level.
Old Aug 4, 2004 | 06:25 PM
Jet-Jock's Avatar
Jet-Jock
Now I have to do a search Thermomaster chip. I like the numbers your getting. In the summer I run 198-205 at cruise and 220 stuck in traffic. I've done everything else possible.
Thanks for the info, we'll be looking forward for your next video too!
Old Aug 5, 2004 | 12:17 AM
jodyeastman's Avatar
jodyeastman
Dude, you deserve a grammy. I enjoyed that more than most holywood s**t. Even without the vette that was very good. I look forward to seeing more.
