Help with Ebrake and suspension identification
Old Aug 3, 2004 | 10:36 AM
prauk's Avatar
prauk
2nd Gear
Default Help with Ebrake and suspension identification
I recently started working on a kit car with complete corvette suspension. The entire aluminium suspension is polished. It looks great, but I need some help. The ebrake is inside the rotor in the rear. I need the bracket that mounts the cable to the backing plate. The later models (88-)(?) have the ebrake as part of the caliper? My ebrake is separate from the caliper. I am using Lokar's ebrake cable assembly. Is anyone familiar with this setup? I need that bracket that holds the ecable end to the backing plate or is it bolted to the caliper bracket?
My suspension has the abs sensors on it and with this ebrake setup, I think it is an 86 or 87. Anyone know? Is there any common problems with this suspension/brakes that I should know about?
Who offers caliper rebuild kits?
Thanks in advance.
Old Aug 3, 2004 | 10:52 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Need more info on the parts. How about some pics to help identify what you have?
-JRC-
Old Aug 4, 2004 | 12:10 AM
prauk's Avatar
prauk
2nd Gear
Default pics included
Where can I attach the picts.
Old Aug 4, 2004 | 01:45 AM
JrRifleCoach
Try reading through this thread -JRC-
Link to pic help
To Help with Ebrake and suspension identification
