Header Braces
Old Aug 21, 2004 | 09:55 AM
lefoy84's Avatar
lefoy84
Default Header Braces
I just bought an nice set of coated Heddman headers for my 86. Unfortunately there is no provision for the old alt and a/c braces that attached to the old manifold. Any ideas on how to reattach these braces/
Old Aug 21, 2004 | 09:57 AM
comp's Avatar
comp
doesn't Heddman sell the add-on's
Old Aug 21, 2004 | 11:47 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The only brackets built into the stock headers are the stand-offs at the bolt holes.
You can cut these from steel tubing, so long as the attaching accessory brackets will clear the header tubes.
Old Aug 21, 2004 | 11:24 PM
lefoy84's Avatar
lefoy84
There is not room to to use the stock studs. The headers come with cromed bolts with small heads to clear the tubes. On each side there was a stud that alowed you to attach the a/c and alt braces. The only way I can think of th reinstall the braces is to weld onto the new bolts.
Old Aug 22, 2004 | 01:27 AM
Hippiehead025's Avatar
Hippiehead025
contact summit racing, they;ll help you out. heddmen has relocation brackets tht will be used with theseh eaders ican almost guarantee it. I had to get an a/c relocation bracket for my monte carlo SS when i got their headers. they r about 15-20$ and r thick quality material.
Old Aug 22, 2004 | 04:08 AM
amm0bob's Avatar
amm0bob
From: The last place on earth to get cable... Sacramento
Summit can help with some header brackets Buddy...
Old Aug 22, 2004 | 03:38 PM
lefoy84's Avatar
lefoy84
Thanks for the help. Called Summit and they were clueless. I will call Hedman on Monday about special brackets.
Old Aug 22, 2004 | 05:54 PM
Hippiehead025
call again and talk tp sum1 else, u prollyguy sum goofy F*ck tht dont know anything call again and ask again.
To Header Braces
