Mine has nuts on it. They can be accessed through the 2 small holes on the inside bottom of the hood. It also has 2-sided tape on the emblem when installed.
The new one should come with nuts. When you go to install it, use a small dab of wheel bearing grease inside the socket to hold the nut so you don't drop it inside the hood.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
The nuts from your old emblem are laying in a channel towards the front of your hood and will roll back and forth every time you make a turn. Get one of those flexible magnet thingies and go fishing for them. You can usually find the proper sized nuts at any hardware store. If memory serves me well they are called speed nuts. It is a good idea to put them on the pins when the emblem is off the car (then remove them) as they cut their own threads and will make it easier to start them when you do the actual install.
I think some were bootlegged or didn't get threaded. I bought one on ebay and it's studs were not threaded and it didn't have nuts (guess it was a girl ) So, instead of troubling with sending it back and such I just got out the tap and die set and threaded the studs and found her some nuts.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The posts aren't supposed to be threaded. The nuts cut threads into em when you put em on for the first time.
Actually, I ran mine part on to the posts before putting the emblem in, so that when I did put it in, the nuts would start easier.
And.. I don't think mine came with new nuts. I used a dab of grease in the socket to keep em from disappearing in there. I tried tape but that didn't work. Also, my emblem (GM) didn't come with any adhesive backing... which is good because its unnecessary and makes a mess of the paint. The new GM rear emblem came with adhesive though.
I agree. My front came from G.M. without nuts and without tape.
The rear came with tape. I had a bitch of a time trying to locate the proper metric self cutting nuts so I just tapped the studs.
I replace mine last year on my 92. The original's were metal with threads. The replacments (from Chevy) were plastic without threads. The nuts that fit the metal ones _do not_ fit the plastic replacements. Learned this the hard way.... You need a nut that cuts the plastic.
Well, like everyone said, mine didn't come with nuts either, and the stock ones were threaded metal so I just used a die and threaded the plastic to fit some nuts. Worked great for me. Then I used a small sticky ball of reverse wadded masking tape in socket to hold nuts in socket until threaded on.
When it comes to keeping a nut in a socket or nut driver I put a piece of plastic or electrical tape over the opening of socket and press it over the nut. It stays in place till it is where you want it.
Even if your fumbling around in a out of sight location.
Can't say I can relate to ya on that. I never fumble my nuts.
