Spark PLug Change
Old Aug 31, 2004 | 05:56 PM
Texas White 93's Avatar
Texas White 93
Default Spark PLug Change
I just purchased this Corvette and it has 36000 miles on it. Should I change the plugs. I have most of the service records and the plugs have never been changed. The Owners manual says change at 100,000. Runs real smooth, no missing. I am changing the fluids, and fuel filter, not sure if I should do the plugs. Do most change out the plugs when you first get one?
Old Aug 31, 2004 | 05:59 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Changing the plugs is a major pain. I wouldnt do it considering the mileage and the fact that the car is running well.
Old Aug 31, 2004 | 06:08 PM
Wayne88's Avatar
Wayne88
But throw that 100,000 out the window. Maybe about 50K at the latest.
Old Aug 31, 2004 | 08:06 PM
BILLY D's Avatar
BILLY D
I know someone who went that 100,000 mile route (not on a vette) and one of the electrodes wore down, fell off,got wedged between the piston and cylinder wall and now is looking at a new motor. Even though you have a low mileage vette the plugs have been in there 11 years. Steel threads/aluminum heads/frozen plugs. Change them and use antiseize on the new plugs for piece of mind.
Old Aug 31, 2004 | 08:43 PM
rws.1's Avatar
rws.1
I agree with BillyD. the plugs have been in there a long time if not miles.
I'd change them. The issue is you don't want them seized in place when you do come to change them. So buy some new ones coat them with anti seize and enjoy the ride.
Old Sep 1, 2004 | 12:15 PM
Ruby Fan's Avatar
Ruby Fan
I am almost in the same situation: I just got an '85 with 40K on it and changed the plugs and wires(both probably all orig). I just wanted everything clean/new from scratch. The hardest part are doing the wires, you'll never get them exactly the way the General did it, very tight around the back of the dist. I also changed the air filter, really cheap price on Fram at Wal-Mart. Dist. cap n rotor, also changed the anti-freeze to new 5 year type. This is all the fun stuff Good Luck
Old Sep 1, 2004 | 12:39 PM
F1Fan's Avatar
F1Fan
I'd change them if it were mine.
There's worse cars to change plugs on than a C4.
Old Sep 1, 2004 | 08:29 PM
Jet-Jock's Avatar
Jet-Jock
Couple options to consider... first if its running ok now you'll be fine but if you like to wrench on your Vette you will get intimate with it changing plugs. The first time it can take up to 8 hours, second time half that. The engine should be cold.
Next the stock plugs and wires leave much to be desired. The wires have lots of ohms of resistence somewhere between 230-300. And the AC-Delco Platium plugs have a little puck under the grounding strap that has a tendency to come off.
If you plan to do it in the future do some searches here for all the tips to make the job easier. Remember its an aluminum engine and your putting steel plugs into, so use anti-seize and proper torque is important.
If you don't have the 'red' Helms GM Service Manuals invest in a set. They are worth their weight in gold. And you will need them to properly route the wires, that is a brain teaser and a half.
I elected to go with Taylor Spiro Pro 8mm with NGK TR-55ix Iridium plugs. Based on the info and suggestions here, very happy with them.Taylor's have about a 30 ohm resistance.
Old Sep 2, 2004 | 11:13 AM
Lonnie Wimble's Avatar
Lonnie Wimble
Cruising
I changed the plugs on my '86 last weekend, and it took about an hour to do. The last plug, I believe Cylinder #8, took 1/2 hour by itself.
But it was worth it. Starting and idling is much smoother.
Old Sep 2, 2004 | 11:18 AM
Cozmo's Avatar
Cozmo
If you do decide to change them, I would recommend this combination of wires and plugs. Mind you changing the wires is a major job. The two combined with take a whole day.
Old Sep 2, 2004 | 07:12 PM
Texas White 93
Thanks for everyone's advice, I think I will change all my fluids, fuel filter , S belt now and then change my plugs and wires in the next couple of weeks. I have only had this Corvette for about three weeks now. LOVE IT!
Old Sep 2, 2004 | 11:42 PM
McShagger's Avatar
McShagger
LOL, Ive never changed them and I got over 120K. But Im changing them soon. What Kind of PLUGS should I use?
To Spark PLug Change
