Aluminum vs. Cast Iron Heads
Received 1,404 Likes
On an engine with low CR, like 8-9.5, Iron heads are going to perform a bit better (with port sizing and chamber cc equal).
The biggest advantage for AL is the weight, you might save 30-40lbs off the motor by going to AL heads. You can run higher CR without running into problems.
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Aluminum also has the advantage of being more repairable should they be damaged, which is especially good the more money and work you have in them.
