Headlight motor Died!!
Old Sep 13, 2004 | 12:12 AM
JasonBourne's Avatar
JasonBourne
Default Headlight motor Died!!
Ok here is the story. My mechanic said that both of my headlight motors need to be replaced. I figured as much since they don't go all the way up. The problem is that they cost 250 each!!!!!!!! Can someone help and lead me to a place that is cheaper. I sure hope there is a better price out there. Thanks guys.
Old Sep 13, 2004 | 12:18 AM
xlr8nflorida's Avatar
xlr8nflorida
well i doubt you need motors, you probably just need gears.
You can buy them at ecklers for $10.00 for both sides.
2 hours of your time and they will be like new.
Send me the rest of the $$$. LOL
Old Sep 13, 2004 | 01:04 AM
JasonBourne
oh wow I hope my mechanic isn't trying to rip me off, i've known him for years. Maybe he just didn't know. Thanks i'll bring it up to him when I take it in. Is there any tell tale signs that it is the motor and not gears, or gears and not motor?
Old Sep 13, 2004 | 01:18 AM
EPiC Vette's Avatar
EPiC Vette
You'll be able to hear the motors. If your headlights are "winking" ( pretty common), meaning that the motors run but the lights don't turn all the way up, they can be repaired .
If you don't hear the motors run (or you can check them with the hood up. Turn on the lights and see if the manual **** spins), then the problem lies deeper.
Did both lights quit at the same time?
Old Sep 13, 2004 | 08:17 AM
JasonBourne
I can hear the motors working, usually one light goes up and the other "winks". No they usually don't quit at the same time. Should I tell my mechanic to change the gears?
Old Sep 13, 2004 | 08:52 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
It's probably your bushings. It's a common C4 problem. Go to Home Depot and ask for item number 595609. You will need six (6) of these nylon spacers to repair both lights.
They cost me .69 cents (plus tax) at Home Depot. I'd try this first. Save some ends and do the job yourself. It's not that hard.
Click this link for the installation instructions.
http://www.corvetteforums.net/tech/headlight.html
Old Sep 13, 2004 | 08:54 AM
~SlvrFox~'s Avatar
~SlvrFox~
St. Jude Donor '05
More likely its the bushings. Look for other recent posts about headlights. The original bushing gel material tends to breakdown and turn to a whiteish powder. Look around the motor housing and see if there is a white powder, if there is, all you need is a bushing replacement. No gears.
Old Sep 13, 2004 | 09:52 AM
xlr8nflorida
Yes, I mean the plastic bushings. They are like $10 from Ecklers.
I guess you could go the home depot route - I just prefer to buy the actual part from Ecklers since fixing the headlights is no 5 minute job.
Although all it is is a simple bushing so maybe you can save even more $ if you go to home depot.
I don't think he is trying to rip you off. Actually most mechanics don't want to put bushings in because it does take about 2 hours so at $100 per hour. You pay them $200 and technically your headlight motor can die shortly down the road (not that this is normal) and then you are back at the dealer again upset that you just paid good money and the headlights are broke again. They would rather sell you new parts.
Do the bushing repair. I've had to do about 4 motors in the last 6 years that I have owned 3 C4's. It works great and never a problem with them again.
Old Sep 13, 2004 | 10:25 AM
Scoob's Avatar
Scoob
Exactly. I don't think he's trying to rip you either, he just doesn't know, he's probably not a C4 savant. It would also take him longer than 2 hours the first time. It took me close to 3.5 hours to do mine the first time. No mechanic is going to spend that kind of time, even at $100/hour, to do such a small job.
Go the DIY route. There's some serious satisfaction waiting for you after a job well done.
I did the DIY thing. I even used onedef's suggestion to go to HD. The job is not rocket science but it is time consuming so just take your time and ask questions here if you get stuck.
Old Sep 14, 2004 | 03:00 PM
JasonBourne
I just ordered the bushing from ecklers, I got 6 all together. I just hope this works.
Old Sep 15, 2004 | 12:48 AM
xlr8nflorida
Hey no fear grasshopper, if you are just freewheeling but you can hear the motors, you will be good to go once you put the bushings in
Old Sep 15, 2004 | 02:26 AM
90EXPVette's Avatar
90EXPVette
Not a hard job at all I did one of mine last year...now the other one's winking
Old Sep 15, 2004 | 07:41 AM
onedef92's Avatar
onedef92
You could have listened to me and gone to Home Depot, saved some ends and best of all, NO WAITING. I even posted the installation instructions...
Old Sep 15, 2004 | 12:34 PM
xlr8nflorida
I once heard a service writer say to a customer that his headlight was "winking at him" - this is when the C5's were new.
Needless to say the customer was not very happy
Old Sep 21, 2004 | 11:54 PM
JasonBourne
I got my bushings in the mail. Went to go replace them today and guess what, I couldn't get the headlight motor off. I looked at the instructions but I guess I need some pictures to help me out. Anyone have any?
Old Sep 22, 2004 | 12:17 AM
NightFlight's Avatar
NightFlight
Did mine last weekend; here's a few pictures I took (unfortunately, I used a flash, so they are a little bright).
Once you've removed all the nuts and the one bolt shown in the pictures the light should come right out.
Old Sep 22, 2004 | 07:41 AM
onedef92's Avatar
onedef92
Check these instructions out.
http://www.corvettefever.com/howto/33098/
To Headlight motor Died!!
Old Sep 22, 2004 | 10:36 AM
shribe's Avatar
shribe
On mine, when I turn the lights on or of, the drivers side motor continues to run for about 3 seconds. The whole thing just kind of pulsates, until eventually stopping.. Is that a sign of bushings also?
Old Sep 22, 2004 | 10:59 AM
Scoob's Avatar
Scoob
Mine does that after I replaced the bushings. I get 13 clicks/thumps from the motor after the headlight closes. I'm still searching for the cause.
Old Sep 22, 2004 | 11:37 AM
onedef92's Avatar
onedef92
My driver's side light was doing that for about six seconds after it closed. It made a thunk-a, thunk-a, thunk-a, thunk noise after it closed. I replaced the bushing and voila! Problem solved.
